Date/Time: Sun, 27 Sep 2026 00:47:33 +0000
Data stream delay with Interactive Brokers
View Count: 2896
[2015-02-18 07:29:33]
Nazar - Posts: 6
I'm using SierraChart in conjunction with Interactive Broker's TWS. I'm trading WTI Crude Oil futures on NYMEX (symbol name in TWS is CL). If I open TWS chart and SierraChart chart side-by-side, I can see that there is a slight delay between those chart. Sierra's chart is always behind, maybe 500ms. It can be easily seen especially on the new bars: new bar in SierraChart always appears later than in TWS. Also, I've noticed that sometimes bar's closing price in TWS and SierraChart is different, specifically if bar was closed on the highly volatile move.
[2015-02-18 08:33:04]
Refer to help topic 4:
http://www.sierrachart.com/index.php?page=doc/helpdetails4.html
And help topic 43:
http://www.sierrachart.com/index.php?page=doc/helpdetails43.html
Understand that you are using a substandard data feed from IB and data issues should be expected.
