Date/Time: Sun, 24 Nov 2024 02:30:17 +0000
chart settings - vertical grid line request
View Count: 1806
[2013-05-26 19:35:23] |
User22396 - Posts: 191 |
pls add 'start of trading day' thanks |
[2013-05-26 21:58:44] |
M5amhan - Posts: 468 |
have you tried the "session start" setting?
[2013-05-26 23:19:50] |
thanks for the reply... when i use 'session start' i get 2 vertical lines for my trading day...1 for the evening (globex)session start and 1 for the regular (pit)session...session start works fine if i only setup my chart for 1 session but i have setup 2 sessions so i can quickly toggle between evening and regular also if i use 'day' for globex session i get the vertical line at the midnite time instead of the globex start time |
[2013-05-26 23:20:57] |
also it seems like 'trading day' would make more sense that 24hr standard 'day' setting which is midnite...i noticed that cum delta bars has a setting of 'reset at start of trading day' so i would assume SC can reference 'trading day' easily
Date Time Of Last Edit: 2013-05-26 23:22:56
[2013-05-28 00:20:15] |
This will be added.
[2013-05-28 02:40:34] |
thanks
[2013-05-28 05:01:09] |
There is no need to say thank you. It is only more work for us to review additional postings. Please understand that.
[2013-09-08 14:29:52] |
any update to when it will be added? This will be added. Cheers Sierra Chart Support - Engineering Level |
[2013-09-10 01:50:42] |
This will be out in the next release.
[2013-09-10 02:25:43] |
thanks if possible now or at some future time can you also add start of year? ...not that i use it all the time but would be a nice addition for longer term charts Date Time Of Last Edit: 2013-09-10 02:25:52
[2013-09-10 02:28:26] |
This will have to wait.
