Date/Time: Sun, 22 Dec 2024 05:13:10 +0000
Top step commish problem
View Count: 874
[2015-02-17 18:34:35] |
User27109 - Posts: 21 |
Hello, I am doing Topstep trader, I have set the commission under global settings-> symbol settings-> Es?cme. The trading Dom is set correctly to feb13, the data is recording in rithmic, yet the commission is not being calculated. Any ideas? |
[2015-02-18 03:47:21] |
The commission only applies in the Trade >> Trade Activity Log.
