Date/Time: Sun, 22 Dec 2024 05:28:07 +0000
Extending Rectangle Price Labels Hidden by VbP Bars
View Count: 771
[2015-02-17 14:36:55] |
User765038 - Posts: 22 |
SC, Is there any way I can make extending rectangle price labels clearly visible above VbP bars (like horizontal price labels)? Thanks and regards, Rod |
[2015-02-17 17:39:11] |
Yes. Make sure the rectangles are drawn above the studies and main price graph. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-17 17:39:49
