Date/Time: Mon, 16 Sep 2024 19:23:19 +0000
Quoteboard support for 1 divided by Price study.
View Count: 919
[2015-02-17 14:09:54] |
vectorTrader - Posts: 86 |
Is there any way to get a realtime instrument to display the inverse? For example, I want to add 1/6J to my board but I have do not know of a way to do that? Ultimately, I am looking to track something comparable to usd/jpy in sierra. thanks |
[2015-02-17 17:17:14] |
joshtrader - Posts: 485 |
For your specific case, you likely need to use another instance of SC and connect to the FXCM forex feed, which SC provides and has many forex pairs, and then use a separate quote board for USDJPY.
[2015-02-17 17:40:45] |
We will add an Inverse Price field to the Quote Board.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-17 17:40:59
[2015-02-17 21:16:00] |
Fantastic. Thanks!
