Date/Time: Sun, 22 Dec 2024 05:19:27 +0000
Seeing price on all 3 overlayed but divided charts by region
View Count: 1303
[2015-02-17 13:53:46] |
ripsdips - Posts: 143 |
How do I have the price or value of the 2 charts below the main chart show on the far right as the first, top chart shows? http://www.sierrachart.com/image.php?l=1424181102424.png |
[2015-02-17 17:18:16] |
You need to enable the Value Label on the study that you are using to overlay those charts. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#NameValueLabels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
