Date/Time: Sun, 22 Dec 2024 05:27:04 +0000
Error when opening SC
View Count: 843
[2015-02-17 07:03:29] |
CMG - Posts: 179 |
Hi There, I cannot open SC and I get the errors shown in the attached file. Thanks |
SC error.jpg / V - Attached On 2015-02-17 07:02:57 UTC - Size: 204.83 KB - 339 views |
[2015-02-17 07:56:02] |
This indicates some communication problem from your side. Refer to this page: http://www.sierrachart.com/index.php?page=doc/doc_HTTPCommunicationErrors.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
