Date/Time: Sun, 22 Dec 2024 05:36:50 +0000
Problem to display all targets and stop no correct...
View Count: 804
[2015-02-16 16:49:02] |
User52247 - Posts: 26 |
Hello, I have a probleme to display all targets on charts. I have another problem : Stops are always on 7 Ticks on entry, while the strategy is programmed for stop at 15 Ticks See an example on attached file. Thank you for your answer Best regards, ad101166 |
Attachment Deleted. Attachment Deleted. probleme target.JPG / V - Attached On 2015-02-16 16:44:33 UTC - Size: 116.78 KB - 349 views Attachment Deleted. |
[2015-02-16 17:06:37] |
I use version : 1232 - Download PreRelease (Old spreadsheets)
[2015-02-16 17:22:51] |
It seems clear that the problem is the Trade Window you are using is not for that particular chart you are trading from. What you need to do is go to the chart and select Trade >>Open Trade Window for Chart to open the trade window for that specific chart. If you do not see it select Chart >> Reset Child Windows and try again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
