Date/Time: Sun, 22 Dec 2024 05:33:24 +0000
Global symbol cursor error 1230
View Count: 1189
[2015-02-15 22:37:20]
joshtrader - Posts: 492
When I hold the cursor over a historical daily chart, the global symbol cursor shows 1 day earlier on a "1 day" chart. For example, holding the cursor over Feb 11 on the historical shows the cursor over Feb 10 on the "1 day" chart. However, when holding the cursor on the "1 day" chart, the correct date is highlighted on the daily historical chart. So it's not a 2-way problem. Using 1230
[2015-02-15 23:05:29]
We do not think there is a problem here.
What are the Session Times set to on the 1 Day chart?
[2015-02-15 23:18:44]
9:30:00 to 16:14:59
[2015-02-15 23:20:20]
I can understand how there would be difficulties in comparing days, when one "day" spans across midnight, but that is not the case here. Plus, I do not think that it is desired that the cursor would be different, depending on which chart it is initiated on. Shouldn't there be a one-to-one relationship?
[2015-02-16 00:00:33]
We are checking on this.
