Date/Time: Sun, 22 Dec 2024 05:25:56 +0000
Graphic Setting crash
View Count: 861
[2015-02-15 21:33:28] |
Thib - Posts: 54 |
Hello, When I want to use "Graphic Setting" menu in a detach window (no problem with attach window), Sierra Chart crash. This probleme is only for SC version > 1230. |
[2015-02-15 21:47:42] |
We will look into this.
[2015-02-16 21:47:43] |
This issue has now been corrected. Update Sierra Chart by selecting Help >> Download Prerelease.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-16 21:47:54
