Date/Time: Sun, 22 Dec 2024 05:26:20 +0000
Free Trial
View Count: 820
[2015-02-15 19:49:01]
User88316 - Posts: 5
when I registered for your free trial I had hoped to be able to try your charts with access to 1 min, 5 min and so on using candle stick charts as well as being able to try and use volume profile but evidently this isn't possible because it appears to me I would need your package 5 to do this.
Is this correct?
Would I be able to get these features if I subscribed to a data link. If I cannot access these features than this trial is of no use to me.
Look forward to your response. Thank you,
Roger
[2015-02-15 21:36:38]
A Sierra Chart trial is on service package 5, so you you do have access to all the functionality you described. We are not sure why you conclude otherwise.
Here is the documentation for the Volume by Price study:
http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html
You may want to use the Sierra Chart Historical Data Service to access data that you do not see provided with SC Forex/CFD Data Service which is selected by default. Here is the documentation for this:
http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.html
