Date/Time: Fri, 22 Nov 2024 18:46:42 +0000
[User Discussion] - Zig Zag Chart Calculator/ Multi-point Chart Calculator
View Count: 2212
[2013-05-25 20:03:30] |
AL324 - Posts: 7 |
Good afternoon I find the zig zag tool and chart calculator tool very useful, however I am curious if there is a way to use them together or configure either of them to handle the following scenario. Is it possible to use the zig zag tool to measure price difference, time difference, ect. in the way the chart calculator does? Or is it possible to make the chart calculator handle multiple points so each swing can be measured with one use of the tool? Rather than the chart calculator tool handling two points (a beginning and end point), can I configure it to handle unlimited points, and post the measurements from point to point (at each swing)? Thanks for the help |
[2013-05-28 02:22:13] |
We will look into this, however, we would require that you at least commit to 6 months of usage time at package 3 or 5 before we implement this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-28 02:22:28
