Date/Time: Sun, 22 Dec 2024 05:49:39 +0000
loosing istorical data
View Count: 882
[2015-02-15 11:47:26] |
User596316 - Posts: 4 |
When computer is off loosing istorical data. message log say:error downloading historical intraday data for ESH5.the futures symbol format is invalid.the year must be 2 digits I don"t now how to correct?
[2015-02-15 19:05:48] |
We see you are using the Barchart Data Service, therefore change the symbol to: ESH15. The year must be two digits. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html#ChangingChartSymbol Make sure you change the symbol on all of the charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-15 19:06:36
