Date/Time: Sat, 13 Sep 2025 04:46:08 +0000
Download Failed
View Count: 1414
[2015-02-13 21:49:48]
User16114 - Posts: 153
Hi. After closing SC and then opening SC I am getting a flashing messages alternating very quickly between a blue message saying "Downloading Historical Data. Bars may not appear until done." and a red message saying "Download Failed." in most charts. And the Message Log is open scrolling continuously.
[2015-02-13 22:13:37]
We need to simplify this problem down to one chart.
Restart Sierra Chart and only open one chart and let us know if you see a Download Failed message with that.
[2015-02-13 22:19:42]
opened new chartbook with one ES chart and it is completely blank but, I am using AMP/TTNet data only. Should there be data after 5:15 EST or do I need to wait till Sunday night?
[2015-02-13 22:28:30]
skoosht - Posts: 13
I had the same issue today, it was because AMP never sent me the CME NonPro form to fill out.
Chat with them and ask for the form cme_nonpro_certification
FYI i was getting this error -
HD Request # 2 | Error downloading historical Intraday data for ES-201503-CME. Historical data logon error: Invalid/missing data for service code: ttamp|12.41.48.53:10501 | 2015-02-13 17:29:01 *
Date Time Of Last Edit: 2015-02-13 22:29:57
[2015-02-13 22:59:24]
In response to post #3 re-download the data in the chart with Edit >>Delete All Data and Download. You will now get the data. We have opened it up for the time being.
In regards to this:
This is an issue on the Sierra Chart side which we need to fix. Should be done in about 20 minutes.
Date Time Of Last Edit: 2015-02-13 23:00:58
[2015-02-13 23:08:24]
in response to first sentence in post #5 - I just opened a new chartbook and new ES chart. No data appears. Do I need to wait till Sunday night to see data because my data feed is AMP/TTNet?
also, thanks "skoosht" for your info - I called AMP and they said all is well with my account. good luck!
[2015-02-14 00:32:33]
Provide a copy of the Message Log, by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2015-02-14 01:53:39]
just opened SC - Friday 13th data does not show but earlier chart data is back - no longer getting "Download Failed." Will the 13th fill in when markets open on Sunday night?
Below is the message log if you still want it...
Software version: 1224 | 2015-02-13 20:37:25
Uses New Spreadsheets | 2015-02-13 20:37:25
Usage end date: 2015-03-07 | 2015-02-13 20:37:25
Enabled for: Advanced Features. | 2015-02-13 20:37:25
Enabled for: Sierra Chart Historical Data Service. | 2015-02-13 20:37:25
Allow Support for Sierra Chart Data Feeds is disabled. | 2015-02-13 20:37:25
Active service: AMP/TTNet | 2015-02-13 20:37:25
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-02-13 20:37:25
2015-02-13 20:37:25 Local computer clock time | 2015-02-13 20:37:25
2015-02-14 01:37:25 GMT time | 2015-02-13 20:37:25
2015-02-13 20:37:25 Time zone adjusted time | 2015-02-13 20:37:25
Time difference to server time: 0 seconds. | 2015-02-13 20:37:25
Program path: C:\SierraChartAMPTTNet\ | 2015-02-13 20:37:25
Data Files path: C:\SierraChartAMPTTNet\Data\ | 2015-02-13 20:37:25
OS Version Number: 6.1 | 2015-02-13 20:37:25
Locale Information: C | 2015-02-13 20:37:25
Checking for new symbol settings for tt | 2015-02-13 20:37:25
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-02-13 20:37:25
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-02-13 20:37:25
Symbol settings are up-to-date for tt | 2015-02-13 20:37:26
Files to Open on Start up | Opening file: ES Trading.cht | 2015-02-13 20:37:28
Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-02-13 20:37:28
Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-02-13 20:37:28
Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-02-13 20:37:28
Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-02-13 20:37:28
Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-02-13 20:37:28
Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-02-13 20:37:28
Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-02-13 20:37:28
Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-02-13 20:37:28
Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-02-13 20:37:28
Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-02-13 20:37:28
Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-02-13 20:37:28
Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-02-13 20:37:28
Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-02-13. | 2015-02-13 20:37:28
ESH15/ES-201503-CME [C] Monthly #2 | Symbols used for continuous contract chart: | 2015-02-13 20:37:28
ESH12 | 2015-02-13 20:37:28
ESM12 | 2015-02-13 20:37:28
ESU12 | 2015-02-13 20:37:28
ESZ12 | 2015-02-13 20:37:28
ESH13 | 2015-02-13 20:37:28
ESM13 | 2015-02-13 20:37:28
ESU13 | 2015-02-13 20:37:28
ESZ13 | 2015-02-13 20:37:28
ESH14 | 2015-02-13 20:37:28
ESM14 | 2015-02-13 20:37:28
ESU14 | 2015-02-13 20:37:28
ESZ14 | 2015-02-13 20:37:28
ESH15 | 2015-02-13 20:37:28
Limiting the number of days back for the continuous futures chart to 5.0924025 years based on the account type. | 2015-02-13 20:37:28
Date rule based rollover from ESH10 to next contract occurs at 2010-03-11. | 2015-02-13 20:37:28
Date rule based rollover from ESM10 to next contract occurs at 2010-06-10. | 2015-02-13 20:37:28
Date rule based rollover from ESU10 to next contract occurs at 2010-09-09. | 2015-02-13 20:37:28
Date rule based rollover from ESZ10 to next contract occurs at 2010-12-09. | 2015-02-13 20:37:28
Date rule based rollover from ESH11 to next contract occurs at 2011-03-10. | 2015-02-13 20:37:28
Date rule based rollover from ESM11 to next contract occurs at 2011-06-09. | 2015-02-13 20:37:28
Date rule based rollover from ESU11 to next contract occurs at 2011-09-08. | 2015-02-13 20:37:28
Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-11. | 2015-02-13 20:37:28
Checking Daily data file for symbol ESM10 for the date range from 2010-03-11 to 2010-06-10. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESU10 for the date range from 2010-06-10 to 2010-09-09. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-09. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-10. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-09. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-08. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-02-13. | 2015-02-13 20:37:29
ESH15/ES-201503-CME [C] Yearly #1 | Symbols used for continuous contract chart: | 2015-02-13 20:37:29
ESH10 | 2015-02-13 20:37:29
ESM10 | 2015-02-13 20:37:29
ESU10 | 2015-02-13 20:37:29
ESZ10 | 2015-02-13 20:37:29
ESH11 | 2015-02-13 20:37:29
ESM11 | 2015-02-13 20:37:29
ESU11 | 2015-02-13 20:37:29
ESZ11 | 2015-02-13 20:37:29
ESH12 | 2015-02-13 20:37:29
ESM12 | 2015-02-13 20:37:29
ESU12 | 2015-02-13 20:37:29
ESZ12 | 2015-02-13 20:37:29
ESH13 | 2015-02-13 20:37:29
ESM13 | 2015-02-13 20:37:29
ESU13 | 2015-02-13 20:37:29
ESZ13 | 2015-02-13 20:37:29
ESH14 | 2015-02-13 20:37:29
ESM14 | 2015-02-13 20:37:29
ESU14 | 2015-02-13 20:37:29
ESZ14 | 2015-02-13 20:37:29
ESH15 | 2015-02-13 20:37:29
Date rule based rollover from ES-201406-CME to next contract occurs at 2014-06-12. | 2015-02-13 20:37:29
Date rule based rollover from ES-201409-CME to next contract occurs at 2014-09-11. | 2015-02-13 20:37:29
Date rule based rollover from ES-201412-CME to next contract occurs at 2014-12-11. | 2015-02-13 20:37:29
Date rule based rollover from ES-201503-CME to next contract occurs at 2015-03-12. | 2015-02-13 20:37:29
Checking Intraday data file for symbol ES-201406-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-02-13 20:37:29
Checking Intraday data file for symbol ES-201409-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-02-13 20:37:29
Checking Intraday data file for symbol ES-201412-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-02-13 20:37:29
Intraday data file for ES-201503-CME exists and is empty. Skipping Intraday data download. | 2015-02-13 20:37:29
ES-201503-CME [C] 7 Day #3 | Symbols used for continuous contract chart: | 2015-02-13 20:37:29
ES-201406-CME | 2015-02-13 20:37:29
ES-201409-CME | 2015-02-13 20:37:29
ES-201412-CME | 2015-02-13 20:37:29
ES-201503-CME | 2015-02-13 20:37:29
ES-201503-CME [C] 7 Day #9 | Symbols used for continuous contract chart: | 2015-02-13 20:37:29
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChartAMPTTNet\Data\ES-201503-CME.scid | 2015-02-13 20:37:29
HD Request # 2 | Downloading Historical Daily chart data for ESH15. Starting date: 2015-02-12. Service: ttamp | 2015-02-13 20:37:29
Historical data download counter reset. | 2015-02-13 20:37:29
HD Request # 2 | Requesting historical Daily data for ESH15 starting at 2015-02-11 | 2015-02-13 20:37:29
AMP/TTNet | Connecting. | 2015-02-13 20:37:29
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:37:29
Intraday data recording state for symbol ES-201503-CME is set to download pending. | 2015-02-13 20:37:29
HD Request # 3 | Downloading Intraday chart data for ES-201503-CME to the file ES-201503-CME.scid. Service: ttamp | 2015-02-13 20:37:29
HD Request # 3 | Download start Date-Time: 2014-08-11 21:37:29.0 | 2015-02-13 20:37:29
HD Request # 3 | Using server: ttamp.sierracharts.com port 10149 | 2015-02-13 20:37:29
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-13 20:37:29
HD Request # 2 | Receiving historical Daily data for ESH15 starting at 2015-02-11 | 2015-02-13 20:37:29
Writing historical Daily data for ESH15 to the file ESH15.dly | 2015-02-13 20:37:29
HD Request # 2 | Received 3 records from 2015-02-11 00:00:00 to 2015-02-13 00:00:00 (3.0 days) and wrote 2 records for ESH15 | 2015-02-13 20:37:29
HD Request # 2 | Daily download COMPLETE for ESH15. Completion time: 0s. Unique request ID: 1 | 2015-02-13 20:37:29
Removed historical data download ID 1 | 2015-02-13 20:37:29
Socket (3) | Connected. | 2015-02-13 20:37:29
HD Request # 3 | Sending historical data logon request message. | 2015-02-13 20:37:29
Intraday data recording state for symbol TICK-NYSE is set to download pending. | 2015-02-13 20:37:29
Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-02-13 20:37:29
Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-02-13 20:37:29
Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-02-13 20:37:29
Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-02-13 20:37:29
Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-02-13 20:37:29
Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-02-13 20:37:29
Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-02-13 20:37:29
Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-02-13 20:37:29
Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-02-13 20:37:29
Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-02-13 20:37:29
Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-02-13 20:37:29
Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-02-13 20:37:29
Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-02-13 20:37:29
ESH15/ES-201503-CME [C] Monthly #2 | Symbols used for continuous contract chart: | 2015-02-13 20:37:29
Limiting the number of days back for the continuous futures chart to 5.0924025 years based on the account type. | 2015-02-13 20:37:29
Date rule based rollover from ESH10 to next contract occurs at 2010-03-11. | 2015-02-13 20:37:29
Date rule based rollover from ESM10 to next contract occurs at 2010-06-10. | 2015-02-13 20:37:29
Date rule based rollover from ESU10 to next contract occurs at 2010-09-09. | 2015-02-13 20:37:29
Date rule based rollover from ESZ10 to next contract occurs at 2010-12-09. | 2015-02-13 20:37:29
Date rule based rollover from ESH11 to next contract occurs at 2011-03-10. | 2015-02-13 20:37:29
Date rule based rollover from ESM11 to next contract occurs at 2011-06-09. | 2015-02-13 20:37:29
Date rule based rollover from ESU11 to next contract occurs at 2011-09-08. | 2015-02-13 20:37:29
Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08. | 2015-02-13 20:37:29
Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-11. | 2015-02-13 20:37:29
HD Request # 3 | Requesting Intraday data. Start Date-Time: 2014-08-11 21:37:29. Record interval: 0. Symbol: ES-201503-CME | 2015-02-13 20:37:30
HD Request # 3 | Decompressing data. | 2015-02-13 20:37:30
HD Request # 3 | Receiving Intraday data for ES-201503-CME starting at 2014-10-01 02:58:15 | 2015-02-13 20:37:30
HD Request # 3 | Timestamp of first Intraday data file record written: 2014-10-01 02:58:15 | 2015-02-13 20:37:30
TT FIX Data socket (2) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:37:30
TT FIX Data socket (2) | Shutdown and closed. | 2015-02-13 20:37:30
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:37:30
TT FIX Data: Disconnected. | 2015-02-13 20:37:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:37:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:37:30
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:37:30
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:37:30
AMP/TTNet | Disconnected. | 2015-02-13 20:37:30
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:37:30
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-02-13 20:37:31
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-02-13 20:37:31
AMP/TTNet | Connecting. | 2015-02-13 20:37:35
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:37:35
TT FIX Data socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:37:36
TT FIX Data socket (4) | Shutdown and closed. | 2015-02-13 20:37:36
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:37:36
TT FIX Data: Disconnected. | 2015-02-13 20:37:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:37:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:37:36
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:37:36
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:37:36
AMP/TTNet | Disconnected. | 2015-02-13 20:37:36
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:37:36
AMP/TTNet | Connecting. | 2015-02-13 20:37:41
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:37:41
TT FIX Data socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:37:42
TT FIX Data socket (5) | Shutdown and closed. | 2015-02-13 20:37:42
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:37:42
TT FIX Data: Disconnected. | 2015-02-13 20:37:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:37:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:37:42
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:37:43
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:37:43
AMP/TTNet | Disconnected. | 2015-02-13 20:37:43
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:37:43
AMP/TTNet | Connecting. | 2015-02-13 20:37:48
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:37:48
TT FIX Data socket (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:37:49
TT FIX Data socket (6) | Shutdown and closed. | 2015-02-13 20:37:49
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:37:49
TT FIX Data: Disconnected. | 2015-02-13 20:37:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:37:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:37:49
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:37:49
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:37:49
AMP/TTNet | Disconnected. | 2015-02-13 20:37:49
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:37:49
AMP/TTNet | Connecting. | 2015-02-13 20:37:55
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:37:55
TT FIX Data socket (7) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:37:56
TT FIX Data socket (7) | Shutdown and closed. | 2015-02-13 20:37:56
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:37:56
TT FIX Data: Disconnected. | 2015-02-13 20:37:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:37:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:37:56
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:37:57
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:37:57
AMP/TTNet | Disconnected. | 2015-02-13 20:37:57
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:37:57
AMP/TTNet | Connecting. | 2015-02-13 20:38:05
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:38:05
TT FIX Data socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:38:06
TT FIX Data socket (8) | Shutdown and closed. | 2015-02-13 20:38:06
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:38:06
TT FIX Data: Disconnected. | 2015-02-13 20:38:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:38:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:38:06
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:38:08
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:38:08
AMP/TTNet | Disconnected. | 2015-02-13 20:38:08
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:38:08
AMP/TTNet | Connecting. | 2015-02-13 20:38:16
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:38:16
Socket (3) | Shutdown and closed. | 2015-02-13 20:38:17
The network socket for historical data has been closed. | 2015-02-13 20:38:17
HD Request # 3 | Historical data for ES-201503-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-02-13 20:38:17
HD Request # 3 | Received 24094341 records from 2014-10-01 02:58:15 to 2015-02-13 08:37:25 (135.3 days) and wrote 24094341 records for ES-201503-CME | 2015-02-13 20:38:17
HD Request # 3 | Intraday download COMPLETE for ES-201503-CME. Completion time: 48s. Unique request ID: 2 | 2015-02-13 20:38:17
Removed historical data download ID 2 | 2015-02-13 20:38:17
HD Request # 4 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-02-13 20:38:17
HD Request # 4 | Download start Date-Time: 2015-02-13 17:58:13.0 | 2015-02-13 20:38:17
HD Request # 4 | Using server: ds3.sierracharts.com port 10149 | 2015-02-13 20:38:17
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-13 20:38:17
Socket (10) | Connected. | 2015-02-13 20:38:17
HD Request # 4 | Sending historical data logon request message. | 2015-02-13 20:38:17
HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-02-13 17:58:13. Record interval: 0. Symbol: TICK-NYSE | 2015-02-13 20:38:17
HD Request # 4 | Decompressing data. | 2015-02-13 20:38:18
HD Request # 4 | Receiving Intraday data for TICK-NYSE starting at 2015-02-13 17:58:13 | 2015-02-13 20:38:18
HD Request # 4 | Timestamp of first Intraday data file record written: 2015-02-13 17:58:27 | 2015-02-13 20:38:18
Socket (10) | Shutdown and closed. | 2015-02-13 20:38:18
The network socket for historical data has been closed. | 2015-02-13 20:38:18
TT FIX Data socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:38:18
TT FIX Data socket (9) | Shutdown and closed. | 2015-02-13 20:38:18
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:38:18
TT FIX Data: Disconnected. | 2015-02-13 20:38:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:38:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:38:18
HD Request # 4 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-02-13 20:38:18
HD Request # 4 | Received 926 records from 2015-02-13 17:58:13 to 2015-02-13 18:59:58 (61.7 minutes) and wrote 925 records for TICK-NYSE | 2015-02-13 20:38:18
HD Request # 4 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 3 | 2015-02-13 20:38:18
Removed historical data download ID 3 | 2015-02-13 20:38:18
Chart #7 has tagged chart #6 for full recalculation. Chartbook: ES Trading.cht | 2015-02-13 20:38:18
Chart #6 is performing a full recalculation because it has been tagged. Chartbook: ES Trading.cht | 2015-02-13 20:38:19
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:38:20
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:38:20
AMP/TTNet | Disconnected. | 2015-02-13 20:38:20
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:38:20
AMP/TTNet | Connecting. | 2015-02-13 20:38:25
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:38:25
TT FIX Data socket (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:38:26
TT FIX Data socket (11) | Shutdown and closed. | 2015-02-13 20:38:26
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:38:26
TT FIX Data: Disconnected. | 2015-02-13 20:38:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:38:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:38:26
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:38:26
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:38:26
AMP/TTNet | Disconnected. | 2015-02-13 20:38:26
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:38:26
AMP/TTNet | Connecting. | 2015-02-13 20:38:31
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:38:31
TT FIX Data socket (12) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:38:32
TT FIX Data socket (12) | Shutdown and closed. | 2015-02-13 20:38:32
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:38:32
TT FIX Data: Disconnected. | 2015-02-13 20:38:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:38:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:38:32
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:38:32
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:38:32
AMP/TTNet | Disconnected. | 2015-02-13 20:38:32
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:38:32
AMP/TTNet | Connecting. | 2015-02-13 20:38:37
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:38:37
TT FIX Data socket (13) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:38:38
TT FIX Data socket (13) | Shutdown and closed. | 2015-02-13 20:38:38
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:38:38
TT FIX Data: Disconnected. | 2015-02-13 20:38:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:38:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:38:38
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:38:38
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:38:38
AMP/TTNet | Disconnected. | 2015-02-13 20:38:38
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:38:38
AMP/TTNet | Connecting. | 2015-02-13 20:38:44
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:38:44
TT FIX Data socket (14) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:38:45
TT FIX Data socket (14) | Shutdown and closed. | 2015-02-13 20:38:45
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:38:45
TT FIX Data: Disconnected. | 2015-02-13 20:38:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:38:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:38:45
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:38:45
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:38:45
AMP/TTNet | Disconnected. | 2015-02-13 20:38:45
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:38:45
AMP/TTNet | Connecting. | 2015-02-13 20:38:50
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:38:50
TT FIX Data socket (15) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:38:51
TT FIX Data socket (15) | Shutdown and closed. | 2015-02-13 20:38:51
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:38:51
TT FIX Data: Disconnected. | 2015-02-13 20:38:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:38:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:38:51
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:38:51
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:38:51
AMP/TTNet | Disconnected. | 2015-02-13 20:38:51
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:38:51
AMP/TTNet | Connecting. | 2015-02-13 20:38:56
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:38:56
TT FIX Data socket (16) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:38:57
TT FIX Data socket (16) | Shutdown and closed. | 2015-02-13 20:38:57
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:38:57
TT FIX Data: Disconnected. | 2015-02-13 20:38:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:38:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:38:57
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:38:57
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:38:57
AMP/TTNet | Disconnected. | 2015-02-13 20:38:57
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:38:57
AMP/TTNet | Connecting. | 2015-02-13 20:39:02
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:39:02
TT FIX Data socket (17) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:39:03
TT FIX Data socket (17) | Shutdown and closed. | 2015-02-13 20:39:03
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:39:03
TT FIX Data: Disconnected. | 2015-02-13 20:39:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:39:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:39:03
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:39:03
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:39:03
AMP/TTNet | Disconnected. | 2015-02-13 20:39:03
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:39:03
AMP/TTNet | Connecting. | 2015-02-13 20:39:08
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:39:08
TT FIX Data socket (18) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:39:09
TT FIX Data socket (18) | Shutdown and closed. | 2015-02-13 20:39:09
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:39:09
TT FIX Data: Disconnected. | 2015-02-13 20:39:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:39:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:39:09
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:39:09
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:39:09
AMP/TTNet | Disconnected. | 2015-02-13 20:39:09
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:39:09
AMP/TTNet | Connecting. | 2015-02-13 20:39:14
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:39:14
TT FIX Data socket (19) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:39:15
TT FIX Data socket (19) | Shutdown and closed. | 2015-02-13 20:39:15
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:39:15
TT FIX Data: Disconnected. | 2015-02-13 20:39:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:39:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:39:15
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:39:15
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:39:15
AMP/TTNet | Disconnected. | 2015-02-13 20:39:15
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:39:15
AMP/TTNet | Connecting. | 2015-02-13 20:39:20
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:39:20
TT FIX Data socket (20) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:39:21
TT FIX Data socket (20) | Shutdown and closed. | 2015-02-13 20:39:21
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:39:21
TT FIX Data: Disconnected. | 2015-02-13 20:39:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:39:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:39:21
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:39:21
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:39:21
AMP/TTNet | Disconnected. | 2015-02-13 20:39:21
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:39:21
AMP/TTNet | Connecting. | 2015-02-13 20:39:26
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:39:26
TT FIX Data socket (21) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:39:27
TT FIX Data socket (21) | Shutdown and closed. | 2015-02-13 20:39:27
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:39:27
TT FIX Data: Disconnected. | 2015-02-13 20:39:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:39:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:39:27
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:39:27
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:39:27
AMP/TTNet | Disconnected. | 2015-02-13 20:39:27
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:39:27
AMP/TTNet | Connecting. | 2015-02-13 20:39:32
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:39:32
TT FIX Data socket (22) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:39:33
TT FIX Data socket (22) | Shutdown and closed. | 2015-02-13 20:39:33
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:39:33
TT FIX Data: Disconnected. | 2015-02-13 20:39:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:39:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:39:33
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:39:34
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:39:34
AMP/TTNet | Disconnected. | 2015-02-13 20:39:34
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:39:34
AMP/TTNet | Connecting. | 2015-02-13 20:39:39
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:39:39
TT FIX Data socket (23) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:39:40
TT FIX Data socket (23) | Shutdown and closed. | 2015-02-13 20:39:40
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:39:40
TT FIX Data: Disconnected. | 2015-02-13 20:39:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:39:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:39:40
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:39:40
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:39:40
AMP/TTNet | Disconnected. | 2015-02-13 20:39:40
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:39:40
AMP/TTNet | Connecting. | 2015-02-13 20:39:45
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:39:45
TT FIX Data socket (24) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:39:46
TT FIX Data socket (24) | Shutdown and closed. | 2015-02-13 20:39:46
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:39:46
TT FIX Data: Disconnected. | 2015-02-13 20:39:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:39:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:39:46
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:39:46
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:39:46
AMP/TTNet | Disconnected. | 2015-02-13 20:39:46
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:39:46
AMP/TTNet | Connecting. | 2015-02-13 20:39:51
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:39:51
TT FIX Data socket (25) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:39:52
TT FIX Data socket (25) | Shutdown and closed. | 2015-02-13 20:39:52
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:39:52
TT FIX Data: Disconnected. | 2015-02-13 20:39:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:39:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:39:52
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:39:52
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:39:52
AMP/TTNet | Disconnected. | 2015-02-13 20:39:52
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:39:52
AMP/TTNet | Connecting. | 2015-02-13 20:39:57
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:39:57
TT FIX Data socket (26) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:39:58
TT FIX Data socket (26) | Shutdown and closed. | 2015-02-13 20:39:58
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:39:58
TT FIX Data: Disconnected. | 2015-02-13 20:39:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:39:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:39:58
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:39:58
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:39:58
AMP/TTNet | Disconnected. | 2015-02-13 20:39:58
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:39:58
AMP/TTNet | Connecting. | 2015-02-13 20:40:03
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:40:03
TT FIX Data socket (27) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:40:04
TT FIX Data socket (27) | Shutdown and closed. | 2015-02-13 20:40:04
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:40:04
TT FIX Data: Disconnected. | 2015-02-13 20:40:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:40:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:40:04
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:40:04
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:40:04
AMP/TTNet | Disconnected. | 2015-02-13 20:40:04
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:40:04
AMP/TTNet | Connecting. | 2015-02-13 20:40:09
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:40:09
TT FIX Data socket (28) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:40:10
TT FIX Data socket (28) | Shutdown and closed. | 2015-02-13 20:40:10
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:40:10
TT FIX Data: Disconnected. | 2015-02-13 20:40:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:40:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:40:10
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:40:10
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:40:10
AMP/TTNet | Disconnected. | 2015-02-13 20:40:10
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:40:10
AMP/TTNet | Connecting. | 2015-02-13 20:40:15
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:40:15
TT FIX Data socket (29) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:40:16
TT FIX Data socket (29) | Shutdown and closed. | 2015-02-13 20:40:16
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:40:16
TT FIX Data: Disconnected. | 2015-02-13 20:40:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:40:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:40:16
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:40:16
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:40:16
AMP/TTNet | Disconnected. | 2015-02-13 20:40:16
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:40:16
AMP/TTNet | Connecting. | 2015-02-13 20:40:21
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-02-13 20:40:21
TT FIX Data socket (30) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 20:40:23
TT FIX Data socket (30) | Shutdown and closed. | 2015-02-13 20:40:23
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-02-13 20:40:23
TT FIX Data: Disconnected. | 2015-02-13 20:40:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 20:40:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 20:40:23
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:40:23
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:40:23
AMP/TTNet | Disconnected. | 2015-02-13 20:40:23
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 20:40:23
File >> Disconnect selected. | 2015-02-13 20:40:24
TT FIX Data: DisconnectFIX called. | 2015-02-13 20:40:24
TT FIX Trading: DisconnectFIX called. | 2015-02-13 20:40:24
AMP/TTNet | Disconnected. | 2015-02-13 20:40:24
[2015-02-14 02:02:30]
You will be able to access the rest of the data by tomorrow morning. To get the data just right-click near the end of the chart and select Delete Data and Download.
Date Time Of Last Edit: 2015-02-14 02:03:04
[2015-02-14 19:13:32]
now have Fri 13th data - almost back to normal, thanks!
but, Chart #9 loading freezes at 63% with chart message...
"Loading... 63% ES-201409-CME Click to cancel"
Chart #9 loading completes when "Use Evening Session" is NOT checked but does not complete when "Use Evening Session" is checked. Chart #9 is a 200 day Continuous Contract Date Rule Rollover chart and has "Include Columns With No Data" checked so that a spreadsheet study is accurate.
below is the message log in case you want it.
(Message log removed)
Date Time Of Last Edit: 2015-02-14 21:18:32
[2015-02-14 21:19:22]
For the problem with charts sometimes not fully loading when using Include Columns with No Data, update to the latest prerelease to solve this.
