Date/Time: Sun, 27 Sep 2026 18:21:22 +0000
Corrupt Minimized Chart Keeps Crashing SC
View Count: 1339
[2015-02-13 19:14:18]
cmet - Posts: 743
How can I get rid of a single chart from a Chartbook?
I have one that's minimized which, until now, has never caused a problem.
If I try to open it, it freezes/crashes SC.
Are individual charts stored somewhere where they can be deleted?
[2015-02-13 19:42:08]
You should be able to right-click on the minimized chart window and select Close.
[2015-02-13 19:44:02]
cmet - Posts: 743
Nope, as soon as I do that, it shows me the command menu and then freezes/crashes.
[2015-02-13 19:56:11]
We do not have another suggestion other than to rebuild the Chartbook. Or delete the chart data file that it depends upon before starting Sierra Chart.
Date Time Of Last Edit: 2015-02-13 19:56:45
[2015-02-13 20:16:52]
cmet - Posts: 743
Aren't charts saved individually somewhere where they can be deleted?
How can I simply save a single chart with all of its indicators and settings so that it doesn't have to be rebuilt from scratch?
[2015-02-14 02:32:37]
Only the chart data files are saved individually. You can delete them through File >> New/Open Intraday Chart.
One thing you can do is create a new Chartbook and then duplicate all the charts you want from an existing Chartbook to that new chartbook. Refer to the documentation here:
http://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#DuplicateChartChartbook
[2015-02-14 02:52:47]
cmet - Posts: 743
Thanks. Was able to delete it after using Edit > Reload All Charts, Save All and relaunch SC.
Date Time Of Last Edit: 2015-02-14 02:53:27
