Date/Time: Sun, 22 Dec 2024 05:35:38 +0000
Stochastic Band Study
View Count: 1244
[2015-02-13 18:44:58] |
kcarey - Posts: 33 |
I am setting up charts on a new computer with the latest download. I am not finding the study Stochastic bands which I use on my old computer. Where can I find this study?
[2015-02-14 02:31:29] |
Not sure about this. We do not see it listed. It sounds somewhat familiar. Possibly it is a user contributed study but we do not see any source code for it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-15 23:15:15
[2015-02-14 19:06:50] |
cmet - Posts: 565 |
Sudies > Add Custom Study > Sierra Chart Custom Studies and Examples > Stochastic Bands Good thing to note that there are many studies in the Sierra Chart Custom Studies and Examples tree that are not present in the default "Studies Available" list. Date Time Of Last Edit: 2015-02-14 19:07:13
[2015-02-14 20:26:16] |
I found them. Had to roll back to v1061 as on old computer and they show up. They are NOT included in the current version for some reason.
[2015-02-14 21:08:21] |
cmet - Posts: 565 |
I have them in the latest version 1224. Not sure if these are the same ones you're using though. http://s30.postimg.org/5cj65n8ox/stochbands.jpg |
[2015-02-15 23:14:04] |
It is a user contributed study and it can be found through: Analysis >> Studies >> Add Custom Study >> Sierra Chart Custom Studies and Examples >> Stochastic Bands Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-15 23:14:17
