Date/Time: Sun, 22 Dec 2024 05:02:04 +0000
Alert on Horizontal Line
View Count: 1346
[2015-02-13 15:23:57]
drywater0 - Posts: 85
SC Support,
Despite checking the box for "Alert Once Per Bar", the alert continually sounds each time price meets the criteria within the same bar. I have tested it on 1m, 5m, and 30m bars and experience the same issue.
Here are my exact settings for the Alert:
Enable Alert for Chart Drawing is checked.
Alert Once Per Bar is checked.
Blink Once Per Bar is checked.
Only Trigger Once is NOT checked.
Last is selected in Study Subgraph.
Crossing or Equal to is selected in Comparison to Drawing.
Comparison Precision is set to .01 for SPY (SP500 index ETF)
Alert Sound is set to Alert 4.
Can you please provide guidance on how to ensure the alert sounds only once in any given bar? Is there a global setting somewhere else that is overriding my choices? Many thanks in advance for your help.
[2015-02-13 22:21:44]
We will check on this.
[2015-02-14 02:06:03]
This will be fixed in the next release.
