Date/Time: Fri, 22 Nov 2024 19:10:09 +0000
[User Discussion] - Acsil Null value?
View Count: 1770
[2013-05-25 18:16:32]
SgtJ - Posts: 154
In an if statement how would I say xyz != an integer. Trying to find a gap in a bar, so something like ..... if (volume != integer)
[2013-05-26 02:06:34]
ejtrader - Posts: 688
SgtJ - Can you elaborate the question or post little more code to see what you are trying to do?
Not sure what you mean by - "gap in a bar.."
Date Time Of Last Edit: 2013-05-26 02:06:56
[2013-05-26 16:51:56]
SgtJ - Posts: 154
You see the hollow square boxes in the attchd image, nothing took place at these levels, no bids/offers on depth or any traded volume.
Looking to use the vap code from post #3
http://www.sierrachart.com/supportboard/showthread.php?t=42052&highlight=elementindex
Date Time Of Last Edit: 2013-05-26 16:52:23
imageprice.PNG / V - Attached On 2013-05-26 16:37:26 UTC - Size: 11.57 KB - 584 views
