Date/Time: Sun, 22 Dec 2024 05:53:17 +0000
Emailed Questions
View Count: 858
[2015-02-13 04:18:20]
Sierra Chart - Max - Posts: 5756
2 years I used the chart sell order column: menu TRADE / TRADING CHART DOM ON. Than I could set the sell column to the left side of the price column (the buy column stayed at the left side of the price column too). Since 1 month the menu GLOBAL SETTINGS / COSTUMIZE CHART DOM COLUMNS / SELL ORDER COLUMN LEFT ALIGNED is not working, not buy right, not sell left. They stay allways at the same default position. I know the old software worked correct. I like please the old software. Please send me the old and correct working software version.The menu GLOBAL SETTINGS / COSTUMIZE TRADE DOM COLUMNS / SELL ORDER COLUMN LEFT ALIGNED is not working too, not buy right, not sell left. They stay allways at the same default position too (see the email attachment please). Please repair this 2 bugs for your next InfinityAT version.
Sierra Chart Support
Date Time Of Last Edit: 2015-02-13 23:23:22
imagechart sell order column setting.jpg / V - Attached On 2015-02-13 23:23:20 UTC - Size: 366.38 KB - 369 views
[2015-02-14 02:36:51]
We see what the problem is.
You need to select Global Settings >> Customize Chart DOM Columns. Instead you are selecting the one for the Trade DOM. But maybe you have already tried that.
Here is the documentation:
http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns
