Date/Time: Sun, 22 Dec 2024 11:34:29 +0000
[User Discussion] - VBP study and price bars
View Count: 857
[2015-02-13 00:13:10] |
User63160 - Posts: 9 |
I am trying to build an analysis that uses both TPO and VBP profiles, and has price bar settings overlaid over the daily profiles. Whenever I add the TPO and VBP studies, the price bars disappear. I have tried changing the Graph Draw type settings to no effect. Thank you.
[2015-02-13 02:27:51] |
This is not supported within Sierra Chart. TPO profiles do not have a direct relationship to the price bars.
