Date/Time: Sun, 22 Dec 2024 11:29:13 +0000
LMax Connection
View Count: 949
[2015-02-12 10:43:32]
User78442 - Posts: 260
Hi, normally I run three SC instances;
Primary - OEC
2nd - SC Historic
3rd - Lmax
Everything works well.
Today I wanted to run the following;
Primary - Lmax
2nd - SC Historic
For some reason the Primary Lmax connection will not connect. It only seems to work as a 3rd session connection. This makes no sense. Usernames and passwords are identical. Any ideas - Recent LOG below;
Software version: 1227 | 2015-02-12 08:33:25
Uses New Spreadsheets | 2015-02-12 08:33:25
Usage end date: 2015-03-07 | 2015-02-12 08:33:25
Enabled for: Advanced Features. | 2015-02-12 08:33:25
Enabled for: Advanced Features 2. | 2015-02-12 08:33:25
Enabled for: Sierra Chart Historical Data Service. | 2015-02-12 08:33:25
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-02-12 08:33:25
Active service: LMAX Trading | 2015-02-12 08:33:25
Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2015-02-12 08:33:25
2015-02-12 08:33:25 Local computer clock time | 2015-02-12 08:33:25
2015-02-12 08:33:25 GMT time | 2015-02-12 08:33:25
2015-02-12 08:33:25 Time zone adjusted time | 2015-02-12 08:33:25
Time difference to server time: 1 seconds. | 2015-02-12 08:33:25
Program path: C:\SierraChart\ | 2015-02-12 08:33:25
Data Files path: C:\SierraChart\Data\ | 2015-02-12 08:33:25
OS Version Number: 6.1 | 2015-02-12 08:33:25
Locale Information: C | 2015-02-12 08:33:25
Checking for new symbol settings for lmax | 2015-02-12 08:33:25
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-02-12 08:33:26
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-02-12 08:33:26
Symbol settings are up-to-date for lmax | 2015-02-12 08:33:26
LMAX Trading | Connecting. | 2015-02-12 08:33:31
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 08:33:31
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 08:33:31
LMAX FIX Trading socket (2) | Connected. | 2015-02-12 08:33:31
LMAX FIX Trading socket (2) | Starting SSL connection. | 2015-02-12 08:33:31
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-02-12 08:33:32
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-02-12 08:33:32
LMAX FIX Trading socket (2) | SSL connection established. | 2015-02-12 08:33:32
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 08:33:32
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 08:33:32
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 08:33:32
LMAX FIX Trading socket (2) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 08:33:32
LMAX FIX Trading socket (2) | SSL has been shut down. | 2015-02-12 08:33:32
LMAX FIX Trading socket (2) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 08:33:32
LMAX FIX Trading socket (2) | Shutdown and closed. | 2015-02-12 08:33:32
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 08:33:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 08:33:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 08:33:32
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 08:33:32
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 08:33:32
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 08:33:32
LMAX Trading | Connecting. | 2015-02-12 08:33:37
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 08:33:37
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 08:33:37
LMAX FIX Trading socket (3) | Connected. | 2015-02-12 08:33:37
LMAX FIX Trading socket (3) | Starting SSL connection. | 2015-02-12 08:33:37
LMAX FIX Trading socket (3) | SSL connection established. | 2015-02-12 08:33:37
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 08:33:37
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 08:33:37
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 08:33:37
LMAX FIX Trading socket (3) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 08:33:37
LMAX FIX Trading socket (3) | SSL has been shut down. | 2015-02-12 08:33:37
LMAX FIX Trading socket (3) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 08:33:37
LMAX FIX Trading socket (3) | Shutdown and closed. | 2015-02-12 08:33:37
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 08:33:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 08:33:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 08:33:37
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 08:33:37
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 08:33:37
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 08:33:37
File >> Disconnect selected. | 2015-02-12 08:33:42
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 08:33:42
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 08:33:42
Current selected Data/Trading service: LMAX Trading | 2015-02-12 08:34:02
LMAX Trading | Connecting. | 2015-02-12 08:34:05
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 08:34:05
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 08:34:05
LMAX FIX Trading socket (4) | Connected. | 2015-02-12 08:34:05
LMAX FIX Trading socket (4) | Starting SSL connection. | 2015-02-12 08:34:05
LMAX FIX Trading socket (4) | SSL connection established. | 2015-02-12 08:34:05
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 08:34:05
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 08:34:05
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 08:34:05
LMAX FIX Trading socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 08:34:05
LMAX FIX Trading socket (4) | SSL has been shut down. | 2015-02-12 08:34:05
LMAX FIX Trading socket (4) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 08:34:05
LMAX FIX Trading socket (4) | Shutdown and closed. | 2015-02-12 08:34:05
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 08:34:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 08:34:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 08:34:05
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 08:34:06
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 08:34:06
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 08:34:06
LMAX Trading | Connecting. | 2015-02-12 08:34:11
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 08:34:11
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 08:34:11
LMAX FIX Trading socket (5) | Connected. | 2015-02-12 08:34:11
LMAX FIX Trading socket (5) | Starting SSL connection. | 2015-02-12 08:34:11
LMAX FIX Trading socket (5) | SSL connection established. | 2015-02-12 08:34:11
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 08:34:11
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 08:34:11
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 08:34:11
LMAX FIX Trading socket (5) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 08:34:11
LMAX FIX Trading socket (5) | SSL has been shut down. | 2015-02-12 08:34:11
LMAX FIX Trading socket (5) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 08:34:11
LMAX FIX Trading socket (5) | Shutdown and closed. | 2015-02-12 08:34:11
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 08:34:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 08:34:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 08:34:11
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 08:34:11
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 08:34:11
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 08:34:11
LMAX Trading | Connecting. | 2015-02-12 08:34:16
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 08:34:16
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 08:34:16
LMAX FIX Trading socket (6) | Connected. | 2015-02-12 08:34:16
LMAX FIX Trading socket (6) | Starting SSL connection. | 2015-02-12 08:34:16
LMAX FIX Trading socket (6) | SSL connection established. | 2015-02-12 08:34:16
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 08:34:16
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 08:34:16
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 08:34:16
LMAX FIX Trading socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 08:34:16
LMAX FIX Trading socket (6) | SSL has been shut down. | 2015-02-12 08:34:16
LMAX FIX Trading socket (6) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 08:34:16
LMAX FIX Trading socket (6) | Shutdown and closed. | 2015-02-12 08:34:16
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 08:34:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 08:34:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 08:34:16
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 08:34:16
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 08:34:16
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 08:34:16
LMAX Trading | Connecting. | 2015-02-12 08:34:21
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 08:34:21
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 08:34:21
LMAX FIX Trading socket (7) | Connected. | 2015-02-12 08:34:21
LMAX FIX Trading socket (7) | Starting SSL connection. | 2015-02-12 08:34:21
LMAX FIX Trading socket (7) | SSL connection established. | 2015-02-12 08:34:21
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 08:34:21
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 08:34:22
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 08:34:22
LMAX FIX Trading socket (7) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 08:34:22
LMAX FIX Trading socket (7) | SSL has been shut down. | 2015-02-12 08:34:22
LMAX FIX Trading socket (7) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 08:34:22
LMAX FIX Trading socket (7) | Shutdown and closed. | 2015-02-12 08:34:22
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 08:34:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 08:34:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 08:34:22
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 08:34:22
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 08:34:22
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 08:34:22
File >> Disconnect selected. | 2015-02-12 08:34:26
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 08:34:26
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 08:34:26
Remote instance connected: C:\SierraChart3\SierraChart.exe | 2015-02-12 08:34:44
Remote instance connected: C:\SierraChart3\SierraChart.exe | 2015-02-12 08:35:16
USDJPY [CBV] [R] 1 Day #4: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 08:35:58
USDJPY [CBV] [R] 1 Day #4: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 08:35:58
USDJPY [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 08:36:03
USDJPY [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 08:36:03
Starting remote Sierra Chart instance "C:\SierraChart2\SierraChart.exe". | 2015-02-12 08:36:03
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): USDJPY.dly, USDJPY.scid | 2015-02-12 08:36:03
HD Request # 2 | Downloading Historical Daily chart data for USDJPY. Starting date: 2015-02-10. Service: lmax | 2015-02-12 08:36:03
HD Request # 2 | Using server: lmax.sierracharts.com port 10149 | 2015-02-12 08:36:03
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-12 08:36:03
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): USDJPY.dly | 2015-02-12 08:36:03
Socket (8) | Connected. | 2015-02-12 08:36:04
HD Request # 2 | Sending historical data logon request message. | 2015-02-12 08:36:04
HD Request # 2 | Requesting historical Daily data starting at 2015-02-10. | 2015-02-12 08:36:04
HD Request # 2 | Decompressing data. | 2015-02-12 08:36:04
HD Request # 2 | Receiving historical Daily data for USDJPY starting at 2015-02-10 | 2015-02-12 08:36:04
Writing historical Daily data for USDJPY to the file USDJPY.dly | 2015-02-12 08:36:04
Socket (8) | Shutdown and closed. | 2015-02-12 08:36:04
The network socket for historical data has been closed. | 2015-02-12 08:36:04
HD Request # 2 | Received 3 records from 2015-02-10 00:00:00 to 2015-02-12 00:00:00 (3.0 days) and wrote 3 records for USDJPY | 2015-02-12 08:36:04
HD Request # 2 | Daily download COMPLETE for USDJPY. Completion time: 1s. Unique request ID: 1 | 2015-02-12 08:36:04
Removed historical data download ID 1 | 2015-02-12 08:36:04
Base Graph DateTime: Out of bounds array error at Index -9307 | 2015-02-12 08:36:09 *
Base Graph DateTime: Out of bounds array error at Index -9301 | 2015-02-12 08:36:09 *
Base Graph DateTime: Out of bounds array error at Index -9297 | 2015-02-12 08:36:09 *
Base Graph DateTime: Out of bounds array error at Index -9295 | 2015-02-12 08:36:09 *
Base Graph DateTime: Out of bounds array error at Index -9293 | 2015-02-12 08:36:09 *
Base Graph DateTime: Out of bounds array error at Index -9291 | 2015-02-12 08:36:09 *
Base Graph DateTime: Out of bounds array error at Index -9289 | 2015-02-12 08:36:09 *
Base Graph DateTime: Out of bounds array error at Index -9299 | 2015-02-12 08:36:09 *
Base Graph DateTime: Out of bounds array error at Index -9285 | 2015-02-12 08:36:09 *
Chart #2 has tagged chart #7 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:09
Chart #5 has tagged chart #2 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:09
Chart #5 has tagged chart #7 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:09
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:09
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:09
Chart #9 has tagged chart #2 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:09
Chart #5 has tagged chart #2 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:10
Chart #5 has tagged chart #7 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:10
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:10
Base Graph DateTime: Out of bounds array error at Index -9307 | 2015-02-12 08:36:10 *
Base Graph DateTime: Out of bounds array error at Index -9301 | 2015-02-12 08:36:10 *
Base Graph DateTime: Out of bounds array error at Index -9297 | 2015-02-12 08:36:10 *
Base Graph DateTime: Out of bounds array error at Index -9295 | 2015-02-12 08:36:10 *
Base Graph DateTime: Out of bounds array error at Index -9293 | 2015-02-12 08:36:10 *
Base Graph DateTime: Out of bounds array error at Index -9291 | 2015-02-12 08:36:10 *
Base Graph DateTime: Out of bounds array error at Index -9289 | 2015-02-12 08:36:10 *
Base Graph DateTime: Out of bounds array error at Index -9299 | 2015-02-12 08:36:10 *
Base Graph DateTime: Out of bounds array error at Index -9285 | 2015-02-12 08:36:10 *
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:10
Chart #2 has tagged chart #7 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:10
Base Graph DateTime: Out of bounds array error at Index -9307 | 2015-02-12 08:36:11 *
Base Graph DateTime: Out of bounds array error at Index -9301 | 2015-02-12 08:36:11 *
Base Graph DateTime: Out of bounds array error at Index -9297 | 2015-02-12 08:36:11 *
Base Graph DateTime: Out of bounds array error at Index -9295 | 2015-02-12 08:36:11 *
Base Graph DateTime: Out of bounds array error at Index -9293 | 2015-02-12 08:36:11 *
Base Graph DateTime: Out of bounds array error at Index -9291 | 2015-02-12 08:36:11 *
Base Graph DateTime: Out of bounds array error at Index -9289 | 2015-02-12 08:36:11 *
Base Graph DateTime: Out of bounds array error at Index -9299 | 2015-02-12 08:36:11 *
Base Graph DateTime: Out of bounds array error at Index -9285 | 2015-02-12 08:36:11 *
Base Graph DateTime: Out of bounds array error at Index -9307 | 2015-02-12 08:36:12 *
Base Graph DateTime: Out of bounds array error at Index -9301 | 2015-02-12 08:36:12 *
Base Graph DateTime: Out of bounds array error at Index -9297 | 2015-02-12 08:36:12 *
Base Graph DateTime: Out of bounds array error at Index -9295 | 2015-02-12 08:36:12 *
Base Graph DateTime: Out of bounds array error at Index -9293 | 2015-02-12 08:36:12 *
Base Graph DateTime: Out of bounds array error at Index -9291 | 2015-02-12 08:36:12 *
Base Graph DateTime: Out of bounds array error at Index -9289 | 2015-02-12 08:36:12 *
Base Graph DateTime: Out of bounds array error at Index -9299 | 2015-02-12 08:36:12 *
Base Graph DateTime: Out of bounds array error at Index -9285 | 2015-02-12 08:36:12 *
Remote instance connected: C:\SierraChart2\SierraChart.exe | 2015-02-12 08:36:12
Requesting data files from remote instance (C:\SierraChart2\SierraChart.exe): AUD-X.scid, CAD-X.scid, CHF-X.scid, EUR-X.scid, GBP-X.scid, JPY-X.scid, NZD-X.scid | 2015-02-12 08:36:12
Chart #4 has tagged chart #2 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:14
Chart #4 has tagged chart #5 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:14
Chart #4 has tagged chart #7 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:14
Base Graph DateTime: Out of bounds array error at Index -9307 | 2015-02-12 08:36:14 *
Base Graph DateTime: Out of bounds array error at Index -9301 | 2015-02-12 08:36:14 *
Base Graph DateTime: Out of bounds array error at Index -9297 | 2015-02-12 08:36:14 *
Base Graph DateTime: Out of bounds array error at Index -9295 | 2015-02-12 08:36:14 *
Base Graph DateTime: Out of bounds array error at Index -9293 | 2015-02-12 08:36:14 *
Base Graph DateTime: Out of bounds array error at Index -9291 | 2015-02-12 08:36:14 *
Base Graph DateTime: Out of bounds array error at Index -9289 | 2015-02-12 08:36:14 *
Base Graph DateTime: Out of bounds array error at Index -9299 | 2015-02-12 08:36:14 *
Base Graph DateTime: Out of bounds array error at Index -9285 | 2015-02-12 08:36:14 *
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:14
Chart #5 has tagged chart #2 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:14
Chart #5 has tagged chart #7 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:14
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:14
Base Graph DateTime: Out of bounds array error at Index -9307 | 2015-02-12 08:36:15 *
Base Graph DateTime: Out of bounds array error at Index -9301 | 2015-02-12 08:36:15 *
Base Graph DateTime: Out of bounds array error at Index -9297 | 2015-02-12 08:36:15 *
Base Graph DateTime: Out of bounds array error at Index -9295 | 2015-02-12 08:36:15 *
Base Graph DateTime: Out of bounds array error at Index -9293 | 2015-02-12 08:36:15 *
Base Graph DateTime: Out of bounds array error at Index -9291 | 2015-02-12 08:36:15 *
Base Graph DateTime: Out of bounds array error at Index -9289 | 2015-02-12 08:36:15 *
Base Graph DateTime: Out of bounds array error at Index -9299 | 2015-02-12 08:36:15 *
Base Graph DateTime: Out of bounds array error at Index -9285 | 2015-02-12 08:36:15 *
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:15
Chart #2 has tagged chart #7 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:15
USDJPY [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 08:36:15
USDJPY [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 08:36:15
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:15
Array message repeat count limit reached. | 2015-02-12 08:36:15 *
Chart #1 has tagged chart #2 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:15
Chart #1 has tagged chart #5 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:15
Chart #1 has tagged chart #7 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:15
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:15
Chart #5 has tagged chart #2 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:15
Chart #5 has tagged chart #7 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:15
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:16
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:16
Chart #2 has tagged chart #7 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:16
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:16
Chart #5 has tagged chart #2 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:16
Chart #5 has tagged chart #7 for full recalculation. Chartbook: USDJPY.cht | 2015-02-12 08:36:16
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: USDJPY.cht | 2015-02-12 08:36:17
EURAUD [CBV] [R] 1 Day #4: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:18:12
EURAUD [CBV] [R] 1 Day #4: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:18:12
EURAUD [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:18:12
EURAUD [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:18:12
Requesting data files from remote instance (C:\SierraChart2\SierraChart.exe): AUD-X.scid, CAD-X.scid, CHF-X.scid, EUR-X.scid, GBP-X.scid, JPY-X.scid, NZD-X.scid | 2015-02-12 10:18:13
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): EURAUD.dly, EURAUD.scid | 2015-02-12 10:18:15
Chart #2 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:16
Chart #5 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:16
Chart #5 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:16
Chart #5 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:17
Chart #5 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:17
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:17
Circular chart reference detected. Charts: 7, 2. Chartbook: EURAUD.cht. | 2015-02-12 10:18:17
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:17
Circular chart reference detected. Charts: 2, 7. Chartbook: EURAUD.cht. | 2015-02-12 10:18:17
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): EURAUD.dly | 2015-02-12 10:18:17
Chart #3 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:17
Chart #3 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:17
Chart #9 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:18
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:18
Circular chart reference detected. Charts: 7, 2. Chartbook: EURAUD.cht. | 2015-02-12 10:18:18
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:18
Circular chart reference detected. Charts: 2, 7. Chartbook: EURAUD.cht. | 2015-02-12 10:18:18
Chart #1 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:25
Chart #1 has tagged chart #5 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:25
Chart #1 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:25
Chart #1 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:26
Chart #1 has tagged chart #5 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:26
Chart #1 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:26
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:26
Circular chart reference detected. Charts: 2, 7. Chartbook: EURAUD.cht. | 2015-02-12 10:18:26
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:26
Circular chart reference detected. Charts: 7, 2. Chartbook: EURAUD.cht. | 2015-02-12 10:18:26
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:26
Chart #5 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:26
Chart #5 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:26
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:27
Circular chart reference detected. Charts: 7, 2. Chartbook: EURAUD.cht. | 2015-02-12 10:18:27
Chart #4 has tagged chart #1 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:28
Chart #4 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:28
Chart #4 has tagged chart #5 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:28
Chart #4 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:28
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:28
Circular chart reference detected. Charts: 7, 2. Chartbook: EURAUD.cht. | 2015-02-12 10:18:28
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:28
Chart #5 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:28
Chart #5 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:28
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:28
Circular chart reference detected. Charts: 2, 7. Chartbook: EURAUD.cht. | 2015-02-12 10:18:28
Chart #4 has tagged chart #1 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Chart #4 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Chart #4 has tagged chart #5 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Chart #4 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Chart #1 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Chart #1 has tagged chart #5 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Chart #1 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Circular chart reference detected. Charts: 7, 2. Chartbook: EURAUD.cht. | 2015-02-12 10:18:29
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Chart #5 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Chart #5 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:29
Circular chart reference detected. Charts: 2, 7. Chartbook: EURAUD.cht. | 2015-02-12 10:18:29
EURAUD [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:18:29
EURAUD [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:18:29
Chart #3 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:30
Chart #3 has tagged chart #7 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:18:30
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:30
Circular chart reference detected. Charts: 7, 2. Chartbook: EURAUD.cht. | 2015-02-12 10:18:30
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:18:30
Circular chart reference detected. Charts: 2, 7. Chartbook: EURAUD.cht. | 2015-02-12 10:18:31
GBPJPY [CBV] [R] 1 Day #4: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:18:46
GBPJPY [CBV] [R] 1 Day #4: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:18:46
GBPJPY [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:18:47
GBPJPY [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:18:47
Requesting data files from remote instance (C:\SierraChart2\SierraChart.exe): AUD-X.scid, CAD-X.scid, CHF-X.scid, EUR-X.scid, GBP-X.scid, JPY-X.scid, NZD-X.scid | 2015-02-12 10:18:47
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): GBPJPY.dly, GBPJPY.scid | 2015-02-12 10:18:49
Chart #7 has tagged chart #2 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:50
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:18:50
Circular chart reference detected. Charts: 7, 2. Chartbook: GBPJPY.cht. | 2015-02-12 10:18:50
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:50
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:50
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:18:50
Circular chart reference detected. Charts: 2, 7. Chartbook: GBPJPY.cht. | 2015-02-12 10:18:50
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): GBPJPY.dly | 2015-02-12 10:18:50
Chart #3 has tagged chart #2 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:51
Chart #3 has tagged chart #7 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:51
Chart #9 has tagged chart #2 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:51
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:18:51
Circular chart reference detected. Charts: 7, 2. Chartbook: GBPJPY.cht. | 2015-02-12 10:18:51
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:18:51
Circular chart reference detected. Charts: 2, 7. Chartbook: GBPJPY.cht. | 2015-02-12 10:18:51
Chart #4 has tagged chart #2 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Chart #4 has tagged chart #5 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Chart #4 has tagged chart #7 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Chart #1 has tagged chart #2 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Chart #1 has tagged chart #5 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Chart #1 has tagged chart #7 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Circular chart reference detected. Charts: 2, 7. Chartbook: GBPJPY.cht. | 2015-02-12 10:18:54
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Circular chart reference detected. Charts: 7, 2. Chartbook: GBPJPY.cht. | 2015-02-12 10:18:54
Chart #4 has tagged chart #1 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:54
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:18:55
Chart #1 has tagged chart #2 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:55
Chart #1 has tagged chart #5 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:55
Chart #1 has tagged chart #7 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:55
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:18:55
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:18:55
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:55
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:18:55
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:18:55
GBPJPY [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:19:01
GBPJPY [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:19:01
Chart #3 has tagged chart #2 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:19:02
Chart #3 has tagged chart #7 for full recalculation. Chartbook: GBPJPY.cht | 2015-02-12 10:19:02
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:19:02
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPJPY.cht | 2015-02-12 10:19:02
GBPCAD [CBV] [R] 1 Day #4: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:19:11
GBPCAD [CBV] [R] 1 Day #4: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:19:11
GBPCAD [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:19:12
GBPCAD [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:19:12
Requesting data files from remote instance (C:\SierraChart2\SierraChart.exe): AUD-X.scid, CAD-X.scid, CHF-X.scid, EUR-X.scid, GBP-X.scid, JPY-X.scid, NZD-X.scid | 2015-02-12 10:19:12
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): GBPCAD.dly, GBPCAD.scid | 2015-02-12 10:19:14
Chart #9 has tagged chart #2 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:15
Chart #7 has tagged chart #2 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:15
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPCAD.cht | 2015-02-12 10:19:15
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:15
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:15
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPCAD.cht | 2015-02-12 10:19:15
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): GBPCAD.dly | 2015-02-12 10:19:15
Chart #3 has tagged chart #2 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:16
Chart #3 has tagged chart #7 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:16
Chart #9 has tagged chart #2 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:16
Chart #4 has tagged chart #2 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:16
Chart #4 has tagged chart #5 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:16
Chart #4 has tagged chart #7 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:16
Chart #1 has tagged chart #2 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:16
Chart #1 has tagged chart #5 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:16
Chart #1 has tagged chart #7 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:16
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPCAD.cht | 2015-02-12 10:19:16
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPCAD.cht | 2015-02-12 10:19:16
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #4 has tagged chart #1 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #4 has tagged chart #2 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #4 has tagged chart #5 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #4 has tagged chart #7 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #1 has tagged chart #2 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #1 has tagged chart #5 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #1 has tagged chart #7 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPCAD.cht | 2015-02-12 10:19:17
GBPCAD [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:19:26
GBPCAD [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:19:26
Chart #3 has tagged chart #2 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:27
Chart #3 has tagged chart #7 for full recalculation. Chartbook: GBPCAD.cht | 2015-02-12 10:19:27
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPCAD.cht | 2015-02-12 10:19:27
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPCAD.cht | 2015-02-12 10:19:27
CADJPY [CBV] [R] 1 Day #4: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:20:01
CADJPY [CBV] [R] 1 Day #4: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:20:01
CADJPY [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:20:01
CADJPY [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:20:01
Requesting data files from remote instance (C:\SierraChart2\SierraChart.exe): AUD-X.scid, CAD-X.scid, CHF-X.scid, EUR-X.scid, GBP-X.scid, JPY-X.scid, NZD-X.scid | 2015-02-12 10:20:01
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): CADJPY.dly, CADJPY.scid | 2015-02-12 10:20:04
Chart #7 has tagged chart #2 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:04
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:05
Chart #5 has tagged chart #2 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:05
Chart #5 has tagged chart #7 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:05
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:05
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): CADJPY.dly | 2015-02-12 10:20:05
Chart #3 has tagged chart #2 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:05
Chart #3 has tagged chart #7 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:05
Chart #9 has tagged chart #2 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:05
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:06
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:06
Chart #4 has tagged chart #2 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:07
Chart #4 has tagged chart #5 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:07
Chart #4 has tagged chart #7 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:07
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:07
Chart #1 has tagged chart #2 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:07
Chart #1 has tagged chart #5 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:07
Chart #1 has tagged chart #7 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:07
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:07
Chart #5 has tagged chart #2 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:07
Chart #5 has tagged chart #7 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:07
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:07
Chart #4 has tagged chart #1 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #4 has tagged chart #2 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #4 has tagged chart #5 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #4 has tagged chart #7 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #1 has tagged chart #2 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #1 has tagged chart #5 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #1 has tagged chart #7 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #5 has tagged chart #2 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #5 has tagged chart #7 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:08
CADJPY [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:20:16
CADJPY [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:20:16
Chart #3 has tagged chart #2 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:16
Chart #3 has tagged chart #7 for full recalculation. Chartbook: CADJPY.cht | 2015-02-12 10:20:16
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:16
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: CADJPY.cht | 2015-02-12 10:20:17
GBPAUD [CBV] [R] 1 Day #4: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:20:27
GBPAUD [CBV] [R] 1 Day #4: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:20:27
GBPAUD [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:20:28
GBPAUD [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:20:28
Requesting data files from remote instance (C:\SierraChart2\SierraChart.exe): AUD-X.scid, CAD-X.scid, CHF-X.scid, EUR-X.scid, GBP-X.scid, JPY-X.scid, NZD-X.scid | 2015-02-12 10:20:28
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): GBPAUD.dly, GBPAUD.scid | 2015-02-12 10:20:31
Chart #2 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:32
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:32
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:32
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:33
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:33
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:33
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:33
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): GBPAUD.dly | 2015-02-12 10:20:34
Chart #3 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:34
Chart #3 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:34
Chart #9 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:34
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:35
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:35
Chart #1 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:43
Chart #1 has tagged chart #5 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:43
Chart #1 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:43
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:43
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:43
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:43
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:43
Chart #1 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:44
Chart #1 has tagged chart #5 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:44
Chart #1 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:44
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:44
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:44
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:44
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:44
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:44
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:45
GBPAUD [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:20:45
GBPAUD [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:20:45
Chart #3 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:46
Chart #3 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:46
Chart #4 has tagged chart #1 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:47
Chart #4 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:47
Chart #4 has tagged chart #5 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:47
Chart #4 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:47
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:47
Chart #1 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:47
Chart #1 has tagged chart #5 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:47
Chart #1 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:47
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:47
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:48
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:48
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:48
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:48
Chart #4 has tagged chart #1 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:49
Chart #4 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:49
Chart #4 has tagged chart #5 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:49
Chart #4 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:49
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:49
Chart #1 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:49
Chart #1 has tagged chart #5 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:49
Chart #1 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:49
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:49
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:49
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPAUD.cht | 2015-02-12 10:20:49
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:50
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPAUD.cht | 2015-02-12 10:20:50
GBPUSD [CBV] [R] 1 Day #4: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:21:00
GBPUSD [CBV] [R] 1 Day #4: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:21:00
GBPUSD [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:21:00
GBPUSD [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:21:00
Requesting data files from remote instance (C:\SierraChart2\SierraChart.exe): AUD-X.scid, CAD-X.scid, CHF-X.scid, EUR-X.scid, GBP-X.scid, JPY-X.scid, NZD-X.scid | 2015-02-12 10:21:01
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): GBPUSD.dly, GBPUSD.scid | 2015-02-12 10:21:03
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:04
Chart #7 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:04
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:05
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:05
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:05
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:05
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): GBPUSD.dly | 2015-02-12 10:21:05
Chart #3 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:05
Chart #3 has tagged chart #7 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:05
Chart #9 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:05
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:06
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:06
Chart #4 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:07
Chart #4 has tagged chart #5 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:07
Chart #4 has tagged chart #7 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:07
Chart #1 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:07
Chart #1 has tagged chart #5 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:07
Chart #1 has tagged chart #7 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:07
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:08
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:08
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:08
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:08
Chart #4 has tagged chart #1 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:08
Chart #4 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:08
Chart #4 has tagged chart #5 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:08
Chart #4 has tagged chart #7 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:08
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:08
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:09
Chart #1 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:09
Chart #1 has tagged chart #5 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:09
Chart #1 has tagged chart #7 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:09
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:09
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:09
Chart #5 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:09
Chart #5 has tagged chart #7 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:09
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:09
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:10
Chart #3 has tagged chart #2 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:17
Chart #3 has tagged chart #7 for full recalculation. Chartbook: GBPUSD.cht | 2015-02-12 10:21:17
GBPUSD [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:21:17
GBPUSD [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:21:17
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:17
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: GBPUSD.cht | 2015-02-12 10:21:18
AUDJPY [CBV] [R] 1 Day #4: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:21:33
AUDJPY [CBV] [R] 1 Day #4: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:21:33
AUDJPY [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:21:34
AUDJPY [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:21:34
Requesting data files from remote instance (C:\SierraChart2\SierraChart.exe): AUD-X.scid, CAD-X.scid, CHF-X.scid, EUR-X.scid, GBP-X.scid, JPY-X.scid, NZD-X.scid | 2015-02-12 10:21:34
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): AUDJPY.dly, AUDJPY.scid | 2015-02-12 10:21:36
Chart #7 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:37
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: AUDJPY.cht | 2015-02-12 10:21:38
Chart #5 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:38
Chart #5 has tagged chart #7 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:38
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: AUDJPY.cht | 2015-02-12 10:21:38
Chart #3 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:38
Chart #3 has tagged chart #7 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:38
HD Request # 3 | Downloading Historical Daily chart data for AUDJPY. Starting date: 2015-02-10. Service: lmax | 2015-02-12 10:21:38
HD Request # 3 | Using server: lmax.sierracharts.com port 10149 | 2015-02-12 10:21:38
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-12 10:21:38
Socket (9) | Connected. | 2015-02-12 10:21:38
HD Request # 3 | Sending historical data logon request message. | 2015-02-12 10:21:38
Chart #9 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:38
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): AUDJPY.dly | 2015-02-12 10:21:38
HD Request # 3 | Requesting historical Daily data starting at 2015-02-10. | 2015-02-12 10:21:38
HD Request # 3 | Decompressing data. | 2015-02-12 10:21:39
HD Request # 3 | Receiving historical Daily data for AUDJPY starting at 2015-02-10 | 2015-02-12 10:21:39
Writing historical Daily data for AUDJPY to the file AUDJPY.dly | 2015-02-12 10:21:39
Socket (9) | Shutdown and closed. | 2015-02-12 10:21:39
The network socket for historical data has been closed. | 2015-02-12 10:21:39
HD Request # 3 | Received 3 records from 2015-02-10 00:00:00 to 2015-02-12 00:00:00 (3.0 days) and wrote 3 records for AUDJPY | 2015-02-12 10:21:39
HD Request # 3 | Daily download COMPLETE for AUDJPY. Completion time: 0s. Unique request ID: 2 | 2015-02-12 10:21:39
Removed historical data download ID 2 | 2015-02-12 10:21:39
Chart #4 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:39
Chart #4 has tagged chart #5 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:39
Chart #4 has tagged chart #7 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:39
Chart #1 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:39
Chart #1 has tagged chart #5 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:39
Chart #1 has tagged chart #7 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:39
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #1 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #1 has tagged chart #5 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #1 has tagged chart #7 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #3 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #3 has tagged chart #7 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #5 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #5 has tagged chart #7 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #4 has tagged chart #1 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #4 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #4 has tagged chart #5 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #4 has tagged chart #7 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:40
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: AUDJPY.cht | 2015-02-12 10:21:41
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: AUDJPY.cht | 2015-02-12 10:21:41
Chart #1 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:41
Chart #1 has tagged chart #5 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:41
Chart #1 has tagged chart #7 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:41
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: AUDJPY.cht | 2015-02-12 10:21:41
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: AUDJPY.cht | 2015-02-12 10:21:41
Chart #5 has tagged chart #2 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:41
Chart #5 has tagged chart #7 for full recalculation. Chartbook: AUDJPY.cht | 2015-02-12 10:21:41
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: AUDJPY.cht | 2015-02-12 10:21:42
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: AUDJPY.cht | 2015-02-12 10:21:43
AUDJPY [CBV] [R] Weekly #6: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:21:51
AUDJPY [CBV] [R] Weekly #6: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:21:51
EURUSD [CBV] [R] 1 Day #4: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-02-12 10:21:53
EURUSD [CBV] [R] 1 Day #4: There are no continuous futures contract symbols. Loading data normally. | 2015-02-12 10:21:53
Requesting data files from remote instance (C:\SierraChart2\SierraChart.exe): AUD-X.scid, CAD-X.scid, CHF-X.scid, EUR-X.scid, GBP-X.scid, JPY-X.scid, NZD-X.scid | 2015-02-12 10:21:54
Requesting data files from remote instance (C:\SierraChart3\SierraChart.exe): EURUSD.scid | 2015-02-12 10:21:56
Chart #7 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:21:57
Chart #5 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:21:57
Chart #5 has tagged chart #7 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:21:57
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:21:58
Chart #5 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:21:58
Chart #5 has tagged chart #7 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:21:58
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:21:58
Chart #3 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:21:58
Chart #3 has tagged chart #7 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:21:58
HD Request # 4 | Downloading Historical Daily chart data for EURUSD. Starting date: 2015-02-10. Service: lmax | 2015-02-12 10:21:58
HD Request # 4 | Using server: lmax.sierracharts.com port 10149 | 2015-02-12 10:21:58
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-12 10:21:58
Socket (10) | Connected. | 2015-02-12 10:21:59
HD Request # 4 | Sending historical data logon request message. | 2015-02-12 10:21:59
Chart #9 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:21:59
HD Request # 4 | Requesting historical Daily data starting at 2015-02-10. | 2015-02-12 10:21:59
HD Request # 4 | Decompressing data. | 2015-02-12 10:21:59
HD Request # 4 | Receiving historical Daily data for EURUSD starting at 2015-02-10 | 2015-02-12 10:21:59
Writing historical Daily data for EURUSD to the file EURUSD.dly | 2015-02-12 10:21:59
Socket (10) | Shutdown and closed. | 2015-02-12 10:21:59
The network socket for historical data has been closed. | 2015-02-12 10:21:59
HD Request # 4 | Received 3 records from 2015-02-10 00:00:00 to 2015-02-12 00:00:00 (3.0 days) and wrote 3 records for EURUSD | 2015-02-12 10:21:59
HD Request # 4 | Daily download COMPLETE for EURUSD. Completion time: 1s. Unique request ID: 3 | 2015-02-12 10:21:59
Removed historical data download ID 3 | 2015-02-12 10:21:59
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:21:59
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:00
Chart #3 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:00
Chart #3 has tagged chart #7 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:00
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:01
Chart #4 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:01
Chart #4 has tagged chart #5 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:01
Chart #4 has tagged chart #7 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:01
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:01
Chart #5 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:01
Chart #5 has tagged chart #7 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:01
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:01
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:02
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:02
Chart #5 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:02
Chart #5 has tagged chart #7 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:02
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:02
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:03
Chart #1 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:04
Chart #1 has tagged chart #5 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:04
Chart #1 has tagged chart #7 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:04
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:04
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:04
Chart #5 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:04
Chart #5 has tagged chart #7 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:04
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:04
Chart #1 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:05
Chart #1 has tagged chart #5 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:05
Chart #1 has tagged chart #7 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:05
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:05
Chart #5 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:05
Chart #5 has tagged chart #2 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:05
Chart #5 has tagged chart #7 for full recalculation. Chartbook: EURUSD.cht | 2015-02-12 10:22:05
Chart #7 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:05
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURUSD.cht | 2015-02-12 10:22:06
Chart #7 has tagged chart #2 for full recalculation. Chartbook: EURAUD.cht | 2015-02-12 10:24:24
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EURAUD.cht | 2015-02-12 10:24:25
Current selected Data/Trading service: LMAX Trading | 2015-02-12 10:25:47
LMAX Trading | Connecting. | 2015-02-12 10:25:50
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:25:50
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:25:50
LMAX FIX Trading socket (11) | Connected. | 2015-02-12 10:25:50
LMAX FIX Trading socket (11) | Starting SSL connection. | 2015-02-12 10:25:50
LMAX FIX Trading socket (11) | SSL connection established. | 2015-02-12 10:25:50
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:25:51
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:25:51
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:25:51
LMAX FIX Trading socket (11) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:25:51
LMAX FIX Trading socket (11) | SSL has been shut down. | 2015-02-12 10:25:51
LMAX FIX Trading socket (11) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:25:51
LMAX FIX Trading socket (11) | Shutdown and closed. | 2015-02-12 10:25:51
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:25:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:25:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:25:51
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:25:51
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:25:51
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:25:51
LMAX Trading | Connecting. | 2015-02-12 10:25:57
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:25:57
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:25:57
LMAX FIX Trading socket (12) | Connected. | 2015-02-12 10:25:57
LMAX FIX Trading socket (12) | Starting SSL connection. | 2015-02-12 10:25:57
LMAX FIX Trading socket (12) | SSL connection established. | 2015-02-12 10:25:57
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:25:59
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:25:59
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:25:59
LMAX FIX Trading socket (12) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:25:59
LMAX FIX Trading socket (12) | SSL has been shut down. | 2015-02-12 10:25:59
LMAX FIX Trading socket (12) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:25:59
LMAX FIX Trading socket (12) | Shutdown and closed. | 2015-02-12 10:25:59
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:25:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:25:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:25:59
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:26:00
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:26:00
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:26:00
LMAX Trading | Connecting. | 2015-02-12 10:26:06
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:26:06
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:26:06
LMAX FIX Trading socket (13) | Connected. | 2015-02-12 10:26:06
LMAX FIX Trading socket (13) | Starting SSL connection. | 2015-02-12 10:26:06
LMAX FIX Trading socket (13) | SSL connection established. | 2015-02-12 10:26:06
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:26:07
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:26:08
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:26:08
LMAX FIX Trading socket (13) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:26:08
LMAX FIX Trading socket (13) | SSL has been shut down. | 2015-02-12 10:26:08
LMAX FIX Trading socket (13) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:26:08
LMAX FIX Trading socket (13) | Shutdown and closed. | 2015-02-12 10:26:08
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:26:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:26:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:26:08
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:26:09
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:26:09
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:26:09
LMAX Trading | Connecting. | 2015-02-12 10:26:15
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:26:15
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:26:15
LMAX FIX Trading socket (14) | Connected. | 2015-02-12 10:26:15
LMAX FIX Trading socket (14) | Starting SSL connection. | 2015-02-12 10:26:15
LMAX FIX Trading socket (14) | SSL connection established. | 2015-02-12 10:26:15
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:26:16
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:26:16
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:26:16
LMAX FIX Trading socket (14) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:26:16
LMAX FIX Trading socket (14) | SSL has been shut down. | 2015-02-12 10:26:16
LMAX FIX Trading socket (14) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:26:16
LMAX FIX Trading socket (14) | Shutdown and closed. | 2015-02-12 10:26:16
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:26:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:26:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:26:16
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:26:17
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:26:17
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:26:17
LMAX Trading | Connecting. | 2015-02-12 10:26:23
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:26:23
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:26:23
LMAX FIX Trading socket (15) | Connected. | 2015-02-12 10:26:23
LMAX FIX Trading socket (15) | Starting SSL connection. | 2015-02-12 10:26:23
LMAX FIX Trading socket (15) | SSL connection established. | 2015-02-12 10:26:24
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:26:25
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:26:25
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:26:25
LMAX FIX Trading socket (15) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:26:25
LMAX FIX Trading socket (15) | SSL has been shut down. | 2015-02-12 10:26:25
LMAX FIX Trading socket (15) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:26:25
LMAX FIX Trading socket (15) | Shutdown and closed. | 2015-02-12 10:26:25
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:26:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:26:25
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:26:25
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:26:26
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:26:26
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:26:26
LMAX Trading | Connecting. | 2015-02-12 10:26:32
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:26:32
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:26:32
LMAX FIX Trading socket (16) | Connected. | 2015-02-12 10:26:32
LMAX FIX Trading socket (16) | Starting SSL connection. | 2015-02-12 10:26:32
LMAX FIX Trading socket (16) | SSL connection established. | 2015-02-12 10:26:32
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:26:34
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:26:34
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:26:34
LMAX FIX Trading socket (16) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:26:34
LMAX FIX Trading socket (16) | SSL has been shut down. | 2015-02-12 10:26:34
LMAX FIX Trading socket (16) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:26:34
LMAX FIX Trading socket (16) | Shutdown and closed. | 2015-02-12 10:26:34
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:26:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:26:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:26:34
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:26:35
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:26:35
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:26:35
LMAX Trading | Connecting. | 2015-02-12 10:26:40
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:26:40
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:26:40
LMAX FIX Trading socket (17) | Connected. | 2015-02-12 10:26:40
LMAX FIX Trading socket (17) | Starting SSL connection. | 2015-02-12 10:26:40
LMAX FIX Trading socket (17) | SSL connection established. | 2015-02-12 10:26:40
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:26:41
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:26:41
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:26:41
LMAX FIX Trading socket (17) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:26:41
LMAX FIX Trading socket (17) | SSL has been shut down. | 2015-02-12 10:26:41
LMAX FIX Trading socket (17) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:26:41
LMAX FIX Trading socket (17) | Shutdown and closed. | 2015-02-12 10:26:41
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:26:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:26:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:26:41
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:26:41
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:26:41
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:26:41
LMAX Trading | Connecting. | 2015-02-12 10:26:46
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:26:46
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:26:46
LMAX FIX Trading socket (18) | Connected. | 2015-02-12 10:26:46
LMAX FIX Trading socket (18) | Starting SSL connection. | 2015-02-12 10:26:46
LMAX FIX Trading socket (18) | SSL connection established. | 2015-02-12 10:26:46
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:26:46
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:26:46
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:26:46
LMAX FIX Trading socket (18) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:26:46
LMAX FIX Trading socket (18) | SSL has been shut down. | 2015-02-12 10:26:46
LMAX FIX Trading socket (18) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:26:46
LMAX FIX Trading socket (18) | Shutdown and closed. | 2015-02-12 10:26:46
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:26:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:26:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:26:46
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:26:46
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:26:46
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:26:46
LMAX Trading | Connecting. | 2015-02-12 10:26:51
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:26:51
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:26:51
LMAX FIX Trading socket (19) | Connected. | 2015-02-12 10:26:51
LMAX FIX Trading socket (19) | Starting SSL connection. | 2015-02-12 10:26:51
LMAX FIX Trading socket (19) | SSL connection established. | 2015-02-12 10:26:51
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:26:51
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:26:51
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:26:51
LMAX FIX Trading socket (19) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:26:51
LMAX FIX Trading socket (19) | SSL has been shut down. | 2015-02-12 10:26:51
LMAX FIX Trading socket (19) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:26:51
LMAX FIX Trading socket (19) | Shutdown and closed. | 2015-02-12 10:26:51
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:26:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:26:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:26:51
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:26:51
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:26:51
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:26:51
LMAX Trading | Connecting. | 2015-02-12 10:26:56
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:26:56
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:26:56
LMAX FIX Trading socket (20) | Connected. | 2015-02-12 10:26:57
LMAX FIX Trading socket (20) | Starting SSL connection. | 2015-02-12 10:26:57
LMAX FIX Trading socket (20) | SSL connection established. | 2015-02-12 10:26:57
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:26:57
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:26:57
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:26:57
LMAX FIX Trading socket (20) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:26:57
LMAX FIX Trading socket (20) | SSL has been shut down. | 2015-02-12 10:26:57
LMAX FIX Trading socket (20) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:26:57
LMAX FIX Trading socket (20) | Shutdown and closed. | 2015-02-12 10:26:57
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:26:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:26:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:26:57
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:26:57
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:26:57
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:26:57
LMAX Trading | Connecting. | 2015-02-12 10:27:02
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:27:02
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:27:02
LMAX FIX Trading socket (21) | Connected. | 2015-02-12 10:27:02
LMAX FIX Trading socket (21) | Starting SSL connection. | 2015-02-12 10:27:02
LMAX FIX Trading socket (21) | SSL connection established. | 2015-02-12 10:27:02
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:27:02
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:27:02
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:27:02
LMAX FIX Trading socket (21) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:27:02
LMAX FIX Trading socket (21) | SSL has been shut down. | 2015-02-12 10:27:02
LMAX FIX Trading socket (21) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:27:02
LMAX FIX Trading socket (21) | Shutdown and closed. | 2015-02-12 10:27:02
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:27:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:27:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:27:02
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:27:02
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:27:02
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:27:02
File >> Disconnect selected. | 2015-02-12 10:27:05
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:27:05
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:27:05
Current selected Data/Trading service: LMAX Trading | 2015-02-12 10:27:20
LMAX Trading | Connecting. | 2015-02-12 10:27:26
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:27:26
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:27:26
LMAX FIX Trading socket (22) | Connected. | 2015-02-12 10:27:26
LMAX FIX Trading socket (22) | Starting SSL connection. | 2015-02-12 10:27:26
LMAX FIX Trading socket (22) | SSL connection established. | 2015-02-12 10:27:26
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:27:26
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:27:26
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:27:26
LMAX FIX Trading socket (22) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:27:26
LMAX FIX Trading socket (22) | SSL has been shut down. | 2015-02-12 10:27:26
LMAX FIX Trading socket (22) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:27:26
LMAX FIX Trading socket (22) | Shutdown and closed. | 2015-02-12 10:27:26
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:27:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:27:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:27:26
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:27:26
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:27:26
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:27:26
LMAX Trading | Connecting. | 2015-02-12 10:27:31
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:27:31
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:27:31
LMAX FIX Trading socket (23) | Connected. | 2015-02-12 10:27:31
LMAX FIX Trading socket (23) | Starting SSL connection. | 2015-02-12 10:27:31
LMAX FIX Trading socket (23) | SSL connection established. | 2015-02-12 10:27:31
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:27:31
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:27:32
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:27:32
LMAX FIX Trading socket (23) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:27:32
LMAX FIX Trading socket (23) | SSL has been shut down. | 2015-02-12 10:27:32
LMAX FIX Trading socket (23) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:27:32
LMAX FIX Trading socket (23) | Shutdown and closed. | 2015-02-12 10:27:32
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:27:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:27:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:27:32
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:27:32
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:27:32
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:27:32
LMAX Trading | Connecting. | 2015-02-12 10:27:37
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:27:37
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:27:37
LMAX FIX Trading socket (24) | Connected. | 2015-02-12 10:27:37
LMAX FIX Trading socket (24) | Starting SSL connection. | 2015-02-12 10:27:37
LMAX FIX Trading socket (24) | SSL connection established. | 2015-02-12 10:27:37
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:27:37
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:27:37
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:27:37
LMAX FIX Trading socket (24) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:27:37
LMAX FIX Trading socket (24) | SSL has been shut down. | 2015-02-12 10:27:37
LMAX FIX Trading socket (24) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:27:37
LMAX FIX Trading socket (24) | Shutdown and closed. | 2015-02-12 10:27:37
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:27:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:27:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:27:37
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:27:37
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:27:37
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:27:37
LMAX Trading | Connecting. | 2015-02-12 10:27:42
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:27:42
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:27:42
LMAX FIX Trading socket (25) | Connected. | 2015-02-12 10:27:42
LMAX FIX Trading socket (25) | Starting SSL connection. | 2015-02-12 10:27:42
LMAX FIX Trading socket (25) | SSL connection established. | 2015-02-12 10:27:42
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:27:42
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:27:42
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:27:42
LMAX FIX Trading socket (25) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:27:42
LMAX FIX Trading socket (25) | SSL has been shut down. | 2015-02-12 10:27:42
LMAX FIX Trading socket (25) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:27:42
LMAX FIX Trading socket (25) | Shutdown and closed. | 2015-02-12 10:27:42
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:27:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:27:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:27:42
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:27:42
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:27:42
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:27:42
LMAX Trading | Connecting. | 2015-02-12 10:27:47
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:27:47
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:27:47
LMAX FIX Trading socket (26) | Connected. | 2015-02-12 10:27:47
LMAX FIX Trading socket (26) | Starting SSL connection. | 2015-02-12 10:27:47
LMAX FIX Trading socket (26) | SSL connection established. | 2015-02-12 10:27:47
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:27:48
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:27:48
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:27:48
LMAX FIX Trading socket (26) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:27:48
LMAX FIX Trading socket (26) | SSL has been shut down. | 2015-02-12 10:27:48
LMAX FIX Trading socket (26) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:27:48
LMAX FIX Trading socket (26) | Shutdown and closed. | 2015-02-12 10:27:48
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:27:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:27:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:27:48
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:27:48
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:27:48
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:27:48
LMAX Trading | Connecting. | 2015-02-12 10:27:53
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:27:53
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:27:53
LMAX FIX Trading socket (27) | Connected. | 2015-02-12 10:27:53
LMAX FIX Trading socket (27) | Starting SSL connection. | 2015-02-12 10:27:53
LMAX FIX Trading socket (27) | SSL connection established. | 2015-02-12 10:27:53
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:27:53
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:27:53
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:27:53
LMAX FIX Trading socket (27) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:27:53
LMAX FIX Trading socket (27) | SSL has been shut down. | 2015-02-12 10:27:53
LMAX FIX Trading socket (27) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:27:53
LMAX FIX Trading socket (27) | Shutdown and closed. | 2015-02-12 10:27:53
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:27:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:27:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:27:53
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:27:53
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:27:53
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:27:53
LMAX Trading | Connecting. | 2015-02-12 10:27:58
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:27:58
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:27:58
LMAX FIX Trading socket (28) | Connected. | 2015-02-12 10:27:58
LMAX FIX Trading socket (28) | Starting SSL connection. | 2015-02-12 10:27:58
LMAX FIX Trading socket (28) | SSL connection established. | 2015-02-12 10:27:58
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:27:58
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:27:58
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:27:58
LMAX FIX Trading socket (28) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:27:58
LMAX FIX Trading socket (28) | SSL has been shut down. | 2015-02-12 10:27:58
LMAX FIX Trading socket (28) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:27:58
LMAX FIX Trading socket (28) | Shutdown and closed. | 2015-02-12 10:27:58
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:27:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:27:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:27:58
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:27:58
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:27:58
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:27:58
LMAX Trading | Connecting. | 2015-02-12 10:28:03
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:28:03
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:28:03
LMAX FIX Trading socket (29) | Connected. | 2015-02-12 10:28:03
LMAX FIX Trading socket (29) | Starting SSL connection. | 2015-02-12 10:28:03
LMAX FIX Trading socket (29) | SSL connection established. | 2015-02-12 10:28:04
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:28:04
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:28:04
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:28:04
LMAX FIX Trading socket (29) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:28:04
LMAX FIX Trading socket (29) | SSL has been shut down. | 2015-02-12 10:28:04
LMAX FIX Trading socket (29) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:28:04
LMAX FIX Trading socket (29) | Shutdown and closed. | 2015-02-12 10:28:04
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:28:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:28:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:28:04
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:28:04
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:28:04
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:28:04
LMAX Trading | Connecting. | 2015-02-12 10:28:09
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:28:09
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:28:09
LMAX FIX Trading socket (30) | Connected. | 2015-02-12 10:28:09
LMAX FIX Trading socket (30) | Starting SSL connection. | 2015-02-12 10:28:09
LMAX FIX Trading socket (30) | SSL connection established. | 2015-02-12 10:28:09
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:28:09
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:28:09
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:28:09
LMAX FIX Trading socket (30) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:28:09
LMAX FIX Trading socket (30) | SSL has been shut down. | 2015-02-12 10:28:09
LMAX FIX Trading socket (30) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:28:09
LMAX FIX Trading socket (30) | Shutdown and closed. | 2015-02-12 10:28:09
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:28:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:28:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:28:09
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:28:09
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:28:09
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:28:09
LMAX Trading | Connecting. | 2015-02-12 10:28:14
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:28:14
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:28:14
LMAX FIX Trading socket (31) | Connected. | 2015-02-12 10:28:14
LMAX FIX Trading socket (31) | Starting SSL connection. | 2015-02-12 10:28:14
LMAX FIX Trading socket (31) | SSL connection established. | 2015-02-12 10:28:14
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:28:14
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:28:14
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:28:14
LMAX FIX Trading socket (31) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:28:14
LMAX FIX Trading socket (31) | SSL has been shut down. | 2015-02-12 10:28:14
LMAX FIX Trading socket (31) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:28:14
LMAX FIX Trading socket (31) | Shutdown and closed. | 2015-02-12 10:28:14
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:28:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:28:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:28:14
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:28:15
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:28:15
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:28:15
LMAX Trading | Connecting. | 2015-02-12 10:28:20
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:28:20
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:28:20
LMAX FIX Trading socket (32) | Connected. | 2015-02-12 10:28:20
LMAX FIX Trading socket (32) | Starting SSL connection. | 2015-02-12 10:28:20
LMAX FIX Trading socket (32) | SSL connection established. | 2015-02-12 10:28:20
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:28:20
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:28:20
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:28:20
LMAX FIX Trading socket (32) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:28:20
LMAX FIX Trading socket (32) | SSL has been shut down. | 2015-02-12 10:28:20
LMAX FIX Trading socket (32) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:28:20
LMAX FIX Trading socket (32) | Shutdown and closed. | 2015-02-12 10:28:20
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:28:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:28:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:28:20
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:28:20
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:28:20
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:28:20
LMAX Trading | Connecting. | 2015-02-12 10:28:25
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:28:25
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:28:25
LMAX FIX Trading socket (33) | Connected. | 2015-02-12 10:28:25
LMAX FIX Trading socket (33) | Starting SSL connection. | 2015-02-12 10:28:25
LMAX FIX Trading socket (33) | SSL connection established. | 2015-02-12 10:28:25
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:28:25
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:28:25
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:28:25
LMAX FIX Trading socket (33) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:28:25
LMAX FIX Trading socket (33) | SSL has been shut down. | 2015-02-12 10:28:25
LMAX FIX Trading socket (33) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:28:25
LMAX FIX Trading socket (33) | Shutdown and closed. | 2015-02-12 10:28:25
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:28:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:28:25
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:28:25
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:28:25
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:28:25
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:28:25
LMAX Trading | Connecting. | 2015-02-12 10:28:30
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:28:30
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:28:30
LMAX FIX Trading socket (34) | Connected. | 2015-02-12 10:28:30
LMAX FIX Trading socket (34) | Starting SSL connection. | 2015-02-12 10:28:30
LMAX FIX Trading socket (34) | SSL connection established. | 2015-02-12 10:28:30
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:28:31
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:28:31
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:28:31
LMAX FIX Trading socket (34) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:28:31
LMAX FIX Trading socket (34) | SSL has been shut down. | 2015-02-12 10:28:31
LMAX FIX Trading socket (34) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:28:31
LMAX FIX Trading socket (34) | Shutdown and closed. | 2015-02-12 10:28:31
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:28:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:28:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:28:31
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:28:31
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:28:31
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:28:31
LMAX Trading | Connecting. | 2015-02-12 10:28:36
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:28:36
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:28:36
LMAX FIX Trading socket (35) | Connected. | 2015-02-12 10:28:36
LMAX FIX Trading socket (35) | Starting SSL connection. | 2015-02-12 10:28:36
LMAX FIX Trading socket (35) | SSL connection established. | 2015-02-12 10:28:36
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:28:36
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:28:36
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:28:36
LMAX FIX Trading socket (35) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:28:36
LMAX FIX Trading socket (35) | SSL has been shut down. | 2015-02-12 10:28:36
LMAX FIX Trading socket (35) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:28:36
LMAX FIX Trading socket (35) | Shutdown and closed. | 2015-02-12 10:28:36
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:28:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:28:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:28:36
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:28:36
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:28:36
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:28:36
LMAX Trading | Connecting. | 2015-02-12 10:28:41
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:28:41
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:28:41
LMAX FIX Trading socket (36) | Connected. | 2015-02-12 10:28:41
LMAX FIX Trading socket (36) | Starting SSL connection. | 2015-02-12 10:28:41
LMAX FIX Trading socket (36) | SSL connection established. | 2015-02-12 10:28:41
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:28:41
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:28:41
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:28:41
LMAX FIX Trading socket (36) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:28:41
LMAX FIX Trading socket (36) | SSL has been shut down. | 2015-02-12 10:28:41
LMAX FIX Trading socket (36) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:28:41
LMAX FIX Trading socket (36) | Shutdown and closed. | 2015-02-12 10:28:41
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:28:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:28:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:28:41
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:28:41
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:28:41
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:28:41
LMAX Trading | Connecting. | 2015-02-12 10:28:46
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:28:46
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:28:46
LMAX FIX Trading socket (37) | Connected. | 2015-02-12 10:28:46
LMAX FIX Trading socket (37) | Starting SSL connection. | 2015-02-12 10:28:46
LMAX FIX Trading socket (37) | SSL connection established. | 2015-02-12 10:28:47
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:28:47
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:28:47
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:28:47
LMAX FIX Trading socket (37) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:28:47
LMAX FIX Trading socket (37) | SSL has been shut down. | 2015-02-12 10:28:47
LMAX FIX Trading socket (37) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:28:47
LMAX FIX Trading socket (37) | Shutdown and closed. | 2015-02-12 10:28:47
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:28:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:28:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:28:47
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:28:47
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:28:47
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:28:47
LMAX Trading | Connecting. | 2015-02-12 10:28:52
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:28:52
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:28:52
LMAX FIX Trading socket (38) | Connected. | 2015-02-12 10:28:52
LMAX FIX Trading socket (38) | Starting SSL connection. | 2015-02-12 10:28:52
LMAX FIX Trading socket (38) | SSL connection established. | 2015-02-12 10:28:52
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:28:52
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:28:52
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:28:52
LMAX FIX Trading socket (38) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:28:52
LMAX FIX Trading socket (38) | SSL has been shut down. | 2015-02-12 10:28:52
LMAX FIX Trading socket (38) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:28:52
LMAX FIX Trading socket (38) | Shutdown and closed. | 2015-02-12 10:28:52
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:28:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:28:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:28:52
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:28:52
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:28:52
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:28:52
LMAX Trading | Connecting. | 2015-02-12 10:28:57
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:28:57
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:28:57
LMAX FIX Trading socket (39) | Connected. | 2015-02-12 10:28:57
LMAX FIX Trading socket (39) | Starting SSL connection. | 2015-02-12 10:28:57
LMAX FIX Trading socket (39) | SSL connection established. | 2015-02-12 10:28:57
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:28:58
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:28:58
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:28:58
LMAX FIX Trading socket (39) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:28:58
LMAX FIX Trading socket (39) | SSL has been shut down. | 2015-02-12 10:28:58
LMAX FIX Trading socket (39) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:28:58
LMAX FIX Trading socket (39) | Shutdown and closed. | 2015-02-12 10:28:58
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:28:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:28:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:28:58
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:28:58
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:28:58
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:28:58
LMAX Trading | Connecting. | 2015-02-12 10:29:03
LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-02-12 10:29:03
LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-02-12 10:29:03
LMAX FIX Trading socket (40) | Connected. | 2015-02-12 10:29:03
LMAX FIX Trading socket (40) | Starting SSL connection. | 2015-02-12 10:29:03
LMAX FIX Trading socket (40) | SSL connection established. | 2015-02-12 10:29:03
LMAX FIX Trading: Sending the Logon message. | 2015-02-12 10:29:03
LMAX FIX Trading: Received a Logout message. Text = User not authorized | 2015-02-12 10:29:03
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-02-12 10:29:03
LMAX FIX Trading socket (40) | SSL shutdown indicates not able to send 'close notify'. | 2015-02-12 10:29:03
LMAX FIX Trading socket (40) | SSL has been shut down. | 2015-02-12 10:29:03
LMAX FIX Trading socket (40) | SSL object has been freed. SSL state is now disconnected. | 2015-02-12 10:29:03
LMAX FIX Trading socket (40) | Shutdown and closed. | 2015-02-12 10:29:03
LMAX FIX Trading: Logged out and disconnected. | 2015-02-12 10:29:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-12 10:29:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-12 10:29:03
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:29:03
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:29:03
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-12 10:29:03
File >> Disconnect selected. | 2015-02-12 10:29:05
LMAX FIX Trading: DisconnectFIX called. | 2015-02-12 10:29:05
LMAX Trading | Disconnected from trade and market data servers. | 2015-02-12 10:29:05
[2015-02-12 11:01:32]
User78442 - Posts: 260
I shifted to scenario 1 and placed a buy order via SC instance 3 on Lmax for 300 Units (Should be 300k) of EURAUD - The chart is tracking the order but it doesn't show on Lmax and I got this log - Any ideas?
Trade Activity Log file read result: 179 records inserted. 0 records filtered. | 2015-02-12 10:45:40
Trade Activity Log file date-time limits: Sim record date-time limit is 2015-01-28 00:00:00. Non-sim record date-time limit is 2014-11-11 00:00:00. Non-sim fill record date-time limit is 2014-05-09 00:00:00. | 2015-02-12 10:45:40
Trade Order Error - LMAX order update (Rejected). Info: EXPOSURE_CHECK_FAILURE. Internal Order ID: 10777. Service Order ID: (none). Symbol: EURAUD | 2015-02-12 10:52:58 *
[2015-02-12 11:27:47]
The order on the chart is enclosed. Initial order 300 Units (300k) - T1=180T, 150 Units (150k) I set the value per Tick @ $0.766 (~ correct as of current crosses), The P&L shows 0.26C? and the 1st close at 180T shows a realised P&L at 2068?? Can you explain these figures? Obviously something is set wrong - at 180T I would calculate the P&L to be $206.82, a factor of 10 out? Have SC or Lmax changed the ratio of SC:Lmax of 10:1? Order chart enc.
imageEURAUD Order_12.02.15.jpg / V - Attached On 2015-02-12 11:27:31 UTC - Size: 68.18 KB - 340 views
[2015-02-12 19:53:33]
Contact LMAX for help with this connection error:
Contact LMAX about the error that is in bold:
We still need to make adjustments to the Currency Value per Tick settings for LMAX for all of the other symbols. For this symbol, the Currency Value per Tick should be .01.
