Date/Time: Mon, 28 Sep 2026 14:46:50 +0000
Project study values into the future on a subgraph
View Count: 1098
| [2015-02-12 02:51:19] |
| flyboy615 - Posts: 56 |
Hi, I have values for my study calculated almost 6 hours in advance, bar by bar and i would like to plot these values forward of the current bar. Is there an easy way to do this? Tried sc.index = 50 which would have been too easy :-). The only way I can think to do this is to use the study displacement and offset my calculation by the same amount backwards. Hard to explain but it would likely work..... any suggestions? Thanks Rob |
| [2015-02-12 04:15:44] |
Refer to: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].ExtendedArrayElementsToGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
