Date/Time: Sun, 22 Dec 2024 05:29:45 +0000
Gene Sheldon
View Count: 1540
[2015-02-11 23:46:54]
User72965 - Posts: 115
I need Data Feed on 2-12
I went in to Help tried to purchase ??
A disaster !!!! Can't figure out ??
Enter country State Broker Then directs me
back to 1st page ????????????????????
No credit addage no nothing ?
Did it 2-3 times It's dead end ??
Don't you want my business or not ?????????
You better get on this one !!!!!
Tomorrow last day on DTN ~~
Looking at Mini ES Follow SPY Also.
Don't have a clue what I need ???
Gene Sheldon
[2015-02-12 08:10:42]
We have answered your question here:
Mr Gene Sheldon | Post: 52670
Please let us know as soon as possible what broker you work with.
[2015-02-12 11:42:57]
I use interactive Brokers I don't think you need Acc't #
That's private ~~~~~~
Time running out ~~
Not sure what i signed up for ???
The purpose is to lower Costs yet keep quality ~~
I'm spending 95.00 month @ the present with IQFeed..
[2015-02-12 18:05:40]
OK therefore, follow the instructions here to set up Sierra Chart to use Interactive Brokers:
https://www.sierrachart.com/index.php?page=doc/IB.php#SetupInstructions
Select File >> Data/Trade Service Settings and enable Allow Support for Sierra Chart Data Feeds.
Press OK.
Open a chart using the Interactive Brokers symbols by selecting File >> Find Symbol. Locate the symbol you want in the list. Only use Interactive Brokers symbols.
Date Time Of Last Edit: 2015-02-12 18:05:57
[2015-02-13 12:52:30]
Well here we are >> NO SIERRA DATA :( ;(
Figured this happen !!!! BUMMER!!!!!!!
You say all's ok It's not !!!!
Far as I know ? All's in place
Using IB trading for Broker ( I downed TWS this a.m. )
The symbols are in place BUT when selected
they don't show up in the s. window (chart settings)
Still have DTN symbol there :(
On the chart heading 9top line) Says >> Interactive Brokers
AND (Sim) Recon Wait- Waiting to connect i assume ..??
Just tried sim acc't No work :( Changed name pass to sim .
Did not work ~~~
Going to need some help on this one ~~ Something to be changed that's beyond me ????
Can you do it from there ???????????? Sure hope so ~~
File Find S. Yes it all there > WON'T RECOGNIZE IT IN S. BOX
USES DTN ???????????????????
[2015-02-13 15:28:46]
Am sending a screenshot Can't get data feed
for session ~~ Am sending text from other computer. Charts on this computer .
Have 2 computers ~~~~~~~~~~~~~
Here's the screen :) Gene
[2015-02-13 15:32:19]
http://www.sierrachart.com/image.php?l=1423841454868.png
Here's screen
[2015-02-13 18:00:25]
What is the problem with the chart in post #7? Is it not updating in real time?
[2015-02-13 18:28:44]
http://www.sierrachart.com/image.php?l=1423851833463.png
Yes not updating in real time ~~`
Get historical date but not real time (current)
Isee the "M" And on top bar see WAIT CONN~~
I think means trying to connect. IB is the broker...
Ck. on your end to see all ok. I think it is ~~~
Missing something ?? Historical ??? Is it or not Real time <> Current data ??
Gene :) Hoping sending screen would help ~~~~~
[2015-02-13 18:36:19]
The problem is you are not able to connect to Interactive Brokers.
For the reason why we need to see the Message Log.
Provide a copy of the Message Log, by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2015-02-13 18:56:08]
Software version: 1220 | 2015-02-13 08:12:22
Uses Old Spreadsheets | 2015-02-13 08:12:22
Usage end date: 2015-04-15 | 2015-02-13 08:12:22
Enabled for: Advanced Features. | 2015-02-13 08:12:22
Enabled for: Advanced Features 2. | 2015-02-13 08:12:22
Enabled for: Sierra Chart Historical Data Service. | 2015-02-13 08:12:22
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2015-02-13 08:12:22
Enabled for: CME, CBOT, NYMEX, COMEX exchanges for trading accounts. | 2015-02-13 08:12:22
Enabled for: S&P INDEXES exchange. | 2015-02-13 08:12:22
Enabled for: CBOE INDEXES exchange. | 2015-02-13 08:12:22
Received 2 data feed usernames. | 2015-02-13 08:12:22
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-02-13 08:12:22
Active service: Interactive Brokers | 2015-02-13 08:12:22
Time Zone: -07:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-02-13 08:12:22
2015-02-13 08:12:22 Local computer clock time | 2015-02-13 08:12:22
2015-02-13 15:12:22 GMT time | 2015-02-13 08:12:22
2015-02-13 08:12:22 Time zone adjusted time | 2015-02-13 08:12:22
Time difference to server time: 32 seconds. | 2015-02-13 08:12:22
WARNING: Your computer's clock is off by 32 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2015-02-13 08:12:23
Program path: C:\SierraChart\ | 2015-02-13 08:12:23
Data Files path: C:\SierraChart\Data\ | 2015-02-13 08:12:23
OS Version Number: 6.1 | 2015-02-13 08:12:23
Locale Information: C | 2015-02-13 08:12:23
Checking for new symbol settings for ib | 2015-02-13 08:12:23
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-02-13 08:12:23
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-02-13 08:12:23
Symbol settings are up-to-date for ib | 2015-02-13 08:12:24
Files to Open on Start up | File does not exist: C:\SierraChart\Data\IOAMT GROUP.cht | 2015-02-13 08:12:26
Files to Open on Start up | File does not exist: C:\SierraChart\Data\6e contract length comp.cht | 2015-02-13 08:12:26
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:12:28
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-02-13 08:12:29
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-02-13 08:12:29
Socket (2) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:12:29
Socket (2) | Shutdown and closed. | 2015-02-13 08:12:29
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:12:29 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:12:29 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:12:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:12:29
Disconnected from IB. | 2015-02-13 08:12:29
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:12:29
Starting TWS auto-login thread. | 2015-02-13 08:12:32
TWS auto-login thread ending. | 2015-02-13 08:12:32
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:12:34
Socket (3) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:12:35
Socket (3) | Shutdown and closed. | 2015-02-13 08:12:35
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:12:35 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:12:35 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:12:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:12:35
Disconnected from IB. | 2015-02-13 08:12:35
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:12:35
Starting TWS auto-login thread. | 2015-02-13 08:12:36
TWS auto-login thread ending. | 2015-02-13 08:12:36
Starting TWS auto-login thread. | 2015-02-13 08:12:40
TWS auto-login thread ending. | 2015-02-13 08:12:40
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:12:40
Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:12:41
Socket (4) | Shutdown and closed. | 2015-02-13 08:12:41
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:12:41 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:12:41 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:12:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:12:41
Disconnected from IB. | 2015-02-13 08:12:41
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:12:41
Starting TWS auto-login thread. | 2015-02-13 08:12:44
TWS auto-login thread ending. | 2015-02-13 08:12:44
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:12:46
Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:12:47
Socket (5) | Shutdown and closed. | 2015-02-13 08:12:47
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:12:47 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:12:47 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:12:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:12:47
Disconnected from IB. | 2015-02-13 08:12:47
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:12:47
Starting TWS auto-login thread. | 2015-02-13 08:12:48
TWS auto-login thread ending. | 2015-02-13 08:12:48
Date rule based rollover from @ESH15 to next contract occurs at 2015-03-12. | 2015-02-13 08:12:50
Checking Intraday data file for symbol @ESH15 for the date range from 2014-12-11 to 0. | 2015-02-13 08:12:50
@ESH15 [C] Renko 2t #2 | Symbols used for continuous contract chart: | 2015-02-13 08:12:50
@ESH15 | 2015-02-13 08:12:50
Date rule based rollover from @ESH15 to next contract occurs at 2015-03-12. | 2015-02-13 08:12:51
Checking Intraday data file for symbol @ESH15 for the date range from 2014-12-11 to 0. | 2015-02-13 08:12:51
@ESH15 [C] 1.25 Range #4 | Symbols used for continuous contract chart: | 2015-02-13 08:12:51
@ESH15 | 2015-02-13 08:12:51
Mapping ES-201503-GLOBEX to ESH15. Service code: cme | 2015-02-13 08:12:56
Intraday data recording state for symbol ES-201503-GLOBEX is set to download pending. | 2015-02-13 08:12:56
HD Request # 2 | Downloading Intraday chart data for ES-201503-GLOBEX to the file ES-201503-GLOBEX.scid. Service: cme | 2015-02-13 08:12:57
HD Request # 2 | Download start Date-Time: 2015-02-13 07:19:18.0 | 2015-02-13 08:12:58
HD Request # 2 | Using server: scdf2.sierracharts.com port 10149 | 2015-02-13 08:12:58
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-02-13 08:12:58
Socket (6) | Connected. | 2015-02-13 08:12:58
HD Request # 2 | Sending historical data logon request message. | 2015-02-13 08:12:58
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:12:58
Starting TWS auto-login thread. | 2015-02-13 08:12:58
TWS auto-login thread ending. | 2015-02-13 08:12:58
HD Request # 2 | Requesting Intraday data. Start Date-Time: 2015-02-13 07:19:18. Record interval: 0. Symbol: ESH15 | 2015-02-13 08:12:58
HD Request # 2 | Decompressing data. | 2015-02-13 08:12:58
HD Request # 2 | Receiving Intraday data for ES-201503-GLOBEX starting at 2015-02-13 07:19:18 | 2015-02-13 08:12:58
HD Request # 2 | Timestamp of first Intraday data file record written: 2015-02-13 07:19:24 | 2015-02-13 08:12:58
Socket (7) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:12:59
Socket (7) | Shutdown and closed. | 2015-02-13 08:12:59
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:12:59 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:12:59 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:12:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:12:59
Disconnected from IB. | 2015-02-13 08:12:59
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:12:59
Starting TWS auto-login thread. | 2015-02-13 08:13:01
TWS auto-login thread ending. | 2015-02-13 08:13:01
HD Request # 2 | Historical data for ES-201503-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-02-13 08:13:01
Socket (6) | Shutdown and closed. | 2015-02-13 08:13:01
The network socket for historical data has been closed. | 2015-02-13 08:13:01
HD Request # 2 | Received 73148 records from 2015-02-13 07:19:18 to 2015-02-13 08:03:31 (44.2 minutes) and wrote 73146 records for ES-201503-GLOBEX | 2015-02-13 08:13:01
HD Request # 2 | Intraday download COMPLETE for ES-201503-GLOBEX. Completion time: 4s. Unique request ID: 1 | 2015-02-13 08:13:01
Removed historical data download ID 1 | 2015-02-13 08:13:01
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:13:04
Starting TWS auto-login thread. | 2015-02-13 08:13:04
TWS auto-login thread ending. | 2015-02-13 08:13:04
Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:13:05
Socket (8) | Shutdown and closed. | 2015-02-13 08:13:05
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:13:05 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:13:05 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:13:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:13:05
Disconnected from IB. | 2015-02-13 08:13:05
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:13:05
Starting TWS auto-login thread. | 2015-02-13 08:13:10
TWS auto-login thread ending. | 2015-02-13 08:13:10
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:13:11
Starting TWS auto-login thread. | 2015-02-13 08:13:12
TWS auto-login thread ending. | 2015-02-13 08:13:12
Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:13:13
Socket (9) | Shutdown and closed. | 2015-02-13 08:13:13
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:13:13 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:13:13 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:13:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:13:13
Disconnected from IB. | 2015-02-13 08:13:13
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:13:13
Warning: The Custom DLL study "SceetoSC.scsf_SceetoESSuperTick" has just caused a CPU exception. | 2015-02-13 08:13:42 *
Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-02-13 08:13:42 *
Starting TWS auto-login thread. | 2015-02-13 08:13:43
TWS auto-login thread ending. | 2015-02-13 08:13:43
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:13:43
Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:13:44
Socket (10) | Shutdown and closed. | 2015-02-13 08:13:44
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:13:44 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:13:44 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:13:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:13:44
Disconnected from IB. | 2015-02-13 08:13:44
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:13:44
Starting TWS auto-login thread. | 2015-02-13 08:13:44
TWS auto-login thread ending. | 2015-02-13 08:13:44
Starting TWS auto-login thread. | 2015-02-13 08:13:48
TWS auto-login thread ending. | 2015-02-13 08:13:48
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:13:49
Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:13:50
Socket (11) | Shutdown and closed. | 2015-02-13 08:13:50
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:13:50 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:13:50 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:13:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:13:50
Disconnected from IB. | 2015-02-13 08:13:50
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:13:50
Starting TWS auto-login thread. | 2015-02-13 08:13:52
TWS auto-login thread ending. | 2015-02-13 08:13:52
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:13:55
Starting TWS auto-login thread. | 2015-02-13 08:13:56
TWS auto-login thread ending. | 2015-02-13 08:13:56
Socket (12) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:13:56
Socket (12) | Shutdown and closed. | 2015-02-13 08:13:56
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:13:56 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:13:56 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:13:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:13:56
Disconnected from IB. | 2015-02-13 08:13:56
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:13:56
Starting TWS auto-login thread. | 2015-02-13 08:14:00
TWS auto-login thread ending. | 2015-02-13 08:14:00
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:14:01
Socket (13) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:14:02
Socket (13) | Shutdown and closed. | 2015-02-13 08:14:02
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:14:02 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:14:02 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:14:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:14:02
Disconnected from IB. | 2015-02-13 08:14:02
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:14:02
Starting TWS auto-login thread. | 2015-02-13 08:14:04
TWS auto-login thread ending. | 2015-02-13 08:14:04
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:14:07
Starting TWS auto-login thread. | 2015-02-13 08:14:08
TWS auto-login thread ending. | 2015-02-13 08:14:08
Socket (14) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:14:09
Socket (14) | Shutdown and closed. | 2015-02-13 08:14:09
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:14:09 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:14:09 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:14:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:14:09
Disconnected from IB. | 2015-02-13 08:14:09
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:14:09
Starting TWS auto-login thread. | 2015-02-13 08:14:12
TWS auto-login thread ending. | 2015-02-13 08:14:12
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:14:14
Socket (15) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:14:15
Socket (15) | Shutdown and closed. | 2015-02-13 08:14:15
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:14:15 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:14:15 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:14:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:14:15
Disconnected from IB. | 2015-02-13 08:14:15
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:14:15
Starting TWS auto-login thread. | 2015-02-13 08:14:16
TWS auto-login thread ending. | 2015-02-13 08:14:16
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:14:20
Starting TWS auto-login thread. | 2015-02-13 08:14:20
TWS auto-login thread ending. | 2015-02-13 08:14:20
Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:14:21
Socket (16) | Shutdown and closed. | 2015-02-13 08:14:21
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:14:21 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:14:21 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:14:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:14:21
Disconnected from IB. | 2015-02-13 08:14:21
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:14:21
Starting TWS auto-login thread. | 2015-02-13 08:14:24
TWS auto-login thread ending. | 2015-02-13 08:14:24
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:14:26
Socket (17) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:14:27
Socket (17) | Shutdown and closed. | 2015-02-13 08:14:27
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:14:27 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:14:27 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:14:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:14:27
Disconnected from IB. | 2015-02-13 08:14:27
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:14:27
Starting TWS auto-login thread. | 2015-02-13 08:14:28
TWS auto-login thread ending. | 2015-02-13 08:14:28
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:14:32
Starting TWS auto-login thread. | 2015-02-13 08:14:32
TWS auto-login thread ending. | 2015-02-13 08:14:32
Socket (18) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:14:33
Socket (18) | Shutdown and closed. | 2015-02-13 08:14:33
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:14:33 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:14:33 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:14:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:14:33
Disconnected from IB. | 2015-02-13 08:14:33
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:14:33
Starting TWS auto-login thread. | 2015-02-13 08:14:36
TWS auto-login thread ending. | 2015-02-13 08:14:37
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:14:38
Socket (19) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:14:39
Socket (19) | Shutdown and closed. | 2015-02-13 08:14:39
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:14:39 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:14:39 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:14:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:14:39
Disconnected from IB. | 2015-02-13 08:14:39
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:14:39
Starting TWS auto-login thread. | 2015-02-13 08:14:41
TWS auto-login thread ending. | 2015-02-13 08:14:41
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:14:44
Starting TWS auto-login thread. | 2015-02-13 08:14:45
TWS auto-login thread ending. | 2015-02-13 08:14:45
Socket (20) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:14:45
Socket (20) | Shutdown and closed. | 2015-02-13 08:14:45
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:14:45 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:14:45 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:14:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:14:45
Disconnected from IB. | 2015-02-13 08:14:45
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:14:45
Starting TWS auto-login thread. | 2015-02-13 08:14:49
TWS auto-login thread ending. | 2015-02-13 08:14:49
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:14:50
Socket (21) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:14:51
Socket (21) | Shutdown and closed. | 2015-02-13 08:14:51
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:14:51 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:14:51 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:14:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:14:51
Disconnected from IB. | 2015-02-13 08:14:51
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:14:51
Starting TWS auto-login thread. | 2015-02-13 08:14:53
TWS auto-login thread ending. | 2015-02-13 08:14:53
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:14:56
Starting TWS auto-login thread. | 2015-02-13 08:14:57
TWS auto-login thread ending. | 2015-02-13 08:14:57
Socket (22) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:14:57
Socket (22) | Shutdown and closed. | 2015-02-13 08:14:57
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:14:57 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:14:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:14:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:14:57
Disconnected from IB. | 2015-02-13 08:14:57
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:14:57
Starting TWS auto-login thread. | 2015-02-13 08:15:01
TWS auto-login thread ending. | 2015-02-13 08:15:01
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:15:02
Socket (23) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:15:03
Socket (23) | Shutdown and closed. | 2015-02-13 08:15:03
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:15:03 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:15:03 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:15:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:15:03
Disconnected from IB. | 2015-02-13 08:15:03
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:15:03
Starting TWS auto-login thread. | 2015-02-13 08:15:05
TWS auto-login thread ending. | 2015-02-13 08:15:05
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:15:08
Starting TWS auto-login thread. | 2015-02-13 08:15:09
TWS auto-login thread ending. | 2015-02-13 08:15:09
Socket (24) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:15:09
Socket (24) | Shutdown and closed. | 2015-02-13 08:15:09
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:15:09 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:15:09 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:15:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:15:09
Disconnected from IB. | 2015-02-13 08:15:09
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:15:09
Starting TWS auto-login thread. | 2015-02-13 08:15:13
TWS auto-login thread ending. | 2015-02-13 08:15:13
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:15:14
Socket (25) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:15:15
Socket (25) | Shutdown and closed. | 2015-02-13 08:15:15
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:15:15 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:15:15 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:15:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:15:15
Disconnected from IB. | 2015-02-13 08:15:15
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:15:15
Starting TWS auto-login thread. | 2015-02-13 08:15:17
TWS auto-login thread ending. | 2015-02-13 08:15:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:15:20
Starting TWS auto-login thread. | 2015-02-13 08:15:21
TWS auto-login thread ending. | 2015-02-13 08:15:21
Socket (26) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:15:21
Socket (26) | Shutdown and closed. | 2015-02-13 08:15:21
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:15:21 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:15:21 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:15:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:15:21
Disconnected from IB. | 2015-02-13 08:15:21
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:15:21
Starting TWS auto-login thread. | 2015-02-13 08:15:25
TWS auto-login thread ending. | 2015-02-13 08:15:25
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:15:26
Socket (27) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:15:27
Socket (27) | Shutdown and closed. | 2015-02-13 08:15:27
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:15:27 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:15:27 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:15:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:15:27
Disconnected from IB. | 2015-02-13 08:15:27
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:15:27
Starting TWS auto-login thread. | 2015-02-13 08:15:29
TWS auto-login thread ending. | 2015-02-13 08:15:29
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:15:32
Starting TWS auto-login thread. | 2015-02-13 08:15:33
TWS auto-login thread ending. | 2015-02-13 08:15:33
Socket (28) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:15:33
Socket (28) | Shutdown and closed. | 2015-02-13 08:15:33
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:15:33 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:15:33 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:15:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:15:33
Disconnected from IB. | 2015-02-13 08:15:33
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:15:33
Starting TWS auto-login thread. | 2015-02-13 08:15:37
TWS auto-login thread ending. | 2015-02-13 08:15:37
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:15:38
Socket (29) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:15:39
Socket (29) | Shutdown and closed. | 2015-02-13 08:15:39
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:15:39 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:15:39 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:15:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:15:39
Disconnected from IB. | 2015-02-13 08:15:39
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:15:39
Starting TWS auto-login thread. | 2015-02-13 08:15:41
TWS auto-login thread ending. | 2015-02-13 08:15:41
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:15:44
Starting TWS auto-login thread. | 2015-02-13 08:15:45
TWS auto-login thread ending. | 2015-02-13 08:15:45
Socket (30) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:15:45
Socket (30) | Shutdown and closed. | 2015-02-13 08:15:45
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:15:45 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:15:45 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:15:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:15:45
Disconnected from IB. | 2015-02-13 08:15:45
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:15:45
Starting TWS auto-login thread. | 2015-02-13 08:15:49
TWS auto-login thread ending. | 2015-02-13 08:15:49
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:15:50
Socket (31) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:15:51
Socket (31) | Shutdown and closed. | 2015-02-13 08:15:51
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:15:51 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:15:51 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:15:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:15:51
Disconnected from IB. | 2015-02-13 08:15:51
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:15:51
Starting TWS auto-login thread. | 2015-02-13 08:15:53
TWS auto-login thread ending. | 2015-02-13 08:15:53
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:15:56
Starting TWS auto-login thread. | 2015-02-13 08:15:57
TWS auto-login thread ending. | 2015-02-13 08:15:57
Socket (32) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:15:57
Socket (32) | Shutdown and closed. | 2015-02-13 08:15:57
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:15:57 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:15:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:15:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:15:57
Disconnected from IB. | 2015-02-13 08:15:57
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:15:57
Starting TWS auto-login thread. | 2015-02-13 08:16:01
TWS auto-login thread ending. | 2015-02-13 08:16:01
Starting TWS auto-login thread. | 2015-02-13 08:16:05
TWS auto-login thread ending. | 2015-02-13 08:16:05
Starting TWS auto-login thread. | 2015-02-13 08:16:09
TWS auto-login thread ending. | 2015-02-13 08:16:09
Starting TWS auto-login thread. | 2015-02-13 08:16:13
TWS auto-login thread ending. | 2015-02-13 08:16:13
Starting TWS auto-login thread. | 2015-02-13 08:16:17
TWS auto-login thread ending. | 2015-02-13 08:16:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:18:57
Socket (33) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:18:58
Socket (33) | Shutdown and closed. | 2015-02-13 08:18:58
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:18:58 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:18:58 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:18:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:18:58
Disconnected from IB. | 2015-02-13 08:18:58
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:18:58
Starting TWS auto-login thread. | 2015-02-13 08:20:17
TWS auto-login thread ending. | 2015-02-13 08:20:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:21:58
Socket (34) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:21:59
Socket (34) | Shutdown and closed. | 2015-02-13 08:21:59
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:21:59 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:21:59 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:21:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:21:59
Disconnected from IB. | 2015-02-13 08:21:59
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:21:59
Starting TWS auto-login thread. | 2015-02-13 08:24:17
TWS auto-login thread ending. | 2015-02-13 08:24:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:24:59
Socket (35) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:25:00
Socket (35) | Shutdown and closed. | 2015-02-13 08:25:00
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:25:00 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:25:00 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:25:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:25:00
Disconnected from IB. | 2015-02-13 08:25:00
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:25:00
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:28:00
Socket (36) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:28:01
Socket (36) | Shutdown and closed. | 2015-02-13 08:28:01
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:28:01 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:28:01 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:28:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:28:01
Disconnected from IB. | 2015-02-13 08:28:02
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:28:02
Starting TWS auto-login thread. | 2015-02-13 08:28:17
TWS auto-login thread ending. | 2015-02-13 08:28:17
Uploaded an image to the server. Request ID: 1 | 2015-02-13 08:30:20
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:31:02
Socket (37) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:31:03
Socket (37) | Shutdown and closed. | 2015-02-13 08:31:03
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:31:03 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:31:03 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:31:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:31:03
Disconnected from IB. | 2015-02-13 08:31:03
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:31:03
Starting TWS auto-login thread. | 2015-02-13 08:32:17
TWS auto-login thread ending. | 2015-02-13 08:32:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:34:03
Socket (38) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:34:04
Socket (38) | Shutdown and closed. | 2015-02-13 08:34:04
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:34:04 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:34:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:34:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:34:04
Disconnected from IB. | 2015-02-13 08:34:04
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:34:04
Starting TWS auto-login thread. | 2015-02-13 08:36:17
TWS auto-login thread ending. | 2015-02-13 08:36:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:37:04
Socket (39) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:37:05
Socket (39) | Shutdown and closed. | 2015-02-13 08:37:05
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:37:05 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:37:05 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:37:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:37:05
Disconnected from IB. | 2015-02-13 08:37:05
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:37:05
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:40:05
Socket (40) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:40:06
Socket (40) | Shutdown and closed. | 2015-02-13 08:40:06
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:40:06 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:40:06 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:40:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:40:06
Disconnected from IB. | 2015-02-13 08:40:06
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:40:06
Starting TWS auto-login thread. | 2015-02-13 08:40:17
TWS auto-login thread ending. | 2015-02-13 08:40:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:43:06
Socket (41) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:43:07
Socket (41) | Shutdown and closed. | 2015-02-13 08:43:07
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:43:07 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:43:07 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:43:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:43:07
Disconnected from IB. | 2015-02-13 08:43:07
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:43:07
Starting TWS auto-login thread. | 2015-02-13 08:44:17
TWS auto-login thread ending. | 2015-02-13 08:44:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:46:07
Socket (42) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:46:08
Socket (42) | Shutdown and closed. | 2015-02-13 08:46:08
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:46:08 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:46:08 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:46:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:46:08
Disconnected from IB. | 2015-02-13 08:46:08
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:46:08
Starting TWS auto-login thread. | 2015-02-13 08:48:17
TWS auto-login thread ending. | 2015-02-13 08:48:17
Date rule based rollover from @ESH15 to next contract occurs at 2015-03-12. | 2015-02-13 08:48:38
Checking Intraday data file for symbol @ESH15 for the date range from 2014-12-11 to 0. | 2015-02-13 08:48:38
@ESH15 [C] Renko 2t #2 | Symbols used for continuous contract chart: | 2015-02-13 08:48:38
@ESH15 | 2015-02-13 08:48:38
Date rule based rollover from @ESH15 to next contract occurs at 2015-03-12. | 2015-02-13 08:48:39
Checking Intraday data file for symbol @ESH15 for the date range from 2014-12-11 to 0. | 2015-02-13 08:48:39
@ESH15 [C] 1.25 Range #4 | Symbols used for continuous contract chart: | 2015-02-13 08:48:39
@ESH15 | 2015-02-13 08:48:39
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:49:09
Socket (43) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:49:10
Socket (43) | Shutdown and closed. | 2015-02-13 08:49:10
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:49:10 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:49:10 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:49:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:49:10
Disconnected from IB. | 2015-02-13 08:49:10
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:49:10
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:52:10
Socket (44) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:52:11
Socket (44) | Shutdown and closed. | 2015-02-13 08:52:11
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:52:11 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:52:11 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:52:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:52:11
Disconnected from IB. | 2015-02-13 08:52:11
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:52:11
Starting TWS auto-login thread. | 2015-02-13 08:52:17
TWS auto-login thread ending. | 2015-02-13 08:52:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:55:11
Socket (45) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:55:12
Socket (45) | Shutdown and closed. | 2015-02-13 08:55:12
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:55:12 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:55:12 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:55:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:55:12
Disconnected from IB. | 2015-02-13 08:55:12
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:55:12
Starting TWS auto-login thread. | 2015-02-13 08:56:17
TWS auto-login thread ending. | 2015-02-13 08:56:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 08:58:12
Socket (46) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 08:58:13
Socket (46) | Shutdown and closed. | 2015-02-13 08:58:13
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 08:58:13 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 08:58:13 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 08:58:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 08:58:13
Disconnected from IB. | 2015-02-13 08:58:13
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 08:58:13
Starting TWS auto-login thread. | 2015-02-13 09:00:17
TWS auto-login thread ending. | 2015-02-13 09:00:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:01:13
Socket (47) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:01:14
Socket (47) | Shutdown and closed. | 2015-02-13 09:01:14
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:01:14 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:01:14 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:01:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:01:14
Disconnected from IB. | 2015-02-13 09:01:14
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:01:14
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:04:14
Socket (48) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:04:15
Socket (48) | Shutdown and closed. | 2015-02-13 09:04:15
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:04:15 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:04:15 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:04:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:04:15
Disconnected from IB. | 2015-02-13 09:04:15
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:04:15
Starting TWS auto-login thread. | 2015-02-13 09:04:17
TWS auto-login thread ending. | 2015-02-13 09:04:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:07:15
Socket (49) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:07:16
Socket (49) | Shutdown and closed. | 2015-02-13 09:07:16
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:07:16 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:07:16 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:07:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:07:16
Disconnected from IB. | 2015-02-13 09:07:16
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:07:16
Starting TWS auto-login thread. | 2015-02-13 09:08:17
TWS auto-login thread ending. | 2015-02-13 09:08:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:10:16
Socket (50) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:10:17
Socket (50) | Shutdown and closed. | 2015-02-13 09:10:17
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:10:17 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:10:17 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:10:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:10:17
Disconnected from IB. | 2015-02-13 09:10:17
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:10:17
Starting TWS auto-login thread. | 2015-02-13 09:12:17
TWS auto-login thread ending. | 2015-02-13 09:12:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:13:17
Socket (51) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:13:18
Socket (51) | Shutdown and closed. | 2015-02-13 09:13:18
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:13:18 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:13:18 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:13:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:13:18
Disconnected from IB. | 2015-02-13 09:13:18
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:13:18
Starting TWS auto-login thread. | 2015-02-13 09:16:17
TWS auto-login thread ending. | 2015-02-13 09:16:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:16:18
Socket (52) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:16:19
Socket (52) | Shutdown and closed. | 2015-02-13 09:16:19
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:16:19 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:16:19 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:16:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:16:19
Disconnected from IB. | 2015-02-13 09:16:19
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:16:19
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:19:19
Socket (53) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:19:20
Socket (53) | Shutdown and closed. | 2015-02-13 09:19:20
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:19:20 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:19:20 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:19:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:19:20
Disconnected from IB. | 2015-02-13 09:19:20
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:19:20
Starting TWS auto-login thread. | 2015-02-13 09:20:17
TWS auto-login thread ending. | 2015-02-13 09:20:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:22:20
Socket (54) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:22:21
Socket (54) | Shutdown and closed. | 2015-02-13 09:22:21
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:22:21 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:22:21 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:22:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:22:21
Disconnected from IB. | 2015-02-13 09:22:21
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:22:21
Starting TWS auto-login thread. | 2015-02-13 09:24:17
TWS auto-login thread ending. | 2015-02-13 09:24:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:25:21
Socket (55) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:25:22
Socket (55) | Shutdown and closed. | 2015-02-13 09:25:22
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:25:22 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:25:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:25:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:25:22
Disconnected from IB. | 2015-02-13 09:25:22
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:25:22
Starting TWS auto-login thread. | 2015-02-13 09:28:17
TWS auto-login thread ending. | 2015-02-13 09:28:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:28:22
Socket (56) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:28:23
Socket (56) | Shutdown and closed. | 2015-02-13 09:28:23
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:28:23 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:28:23 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:28:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:28:23
Disconnected from IB. | 2015-02-13 09:28:23
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:28:23
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:31:23
Socket (57) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:31:24
Socket (57) | Shutdown and closed. | 2015-02-13 09:31:24
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:31:24 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:31:24 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:31:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:31:24
Disconnected from IB. | 2015-02-13 09:31:24
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:31:24
Starting TWS auto-login thread. | 2015-02-13 09:32:17
TWS auto-login thread ending. | 2015-02-13 09:32:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:34:24
Socket (58) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:34:25
Socket (58) | Shutdown and closed. | 2015-02-13 09:34:25
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:34:25 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:34:25 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:34:25
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:34:25
Disconnected from IB. | 2015-02-13 09:34:25
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:34:25
Starting TWS auto-login thread. | 2015-02-13 09:36:17
TWS auto-login thread ending. | 2015-02-13 09:36:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:37:25
Socket (59) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:37:26
Socket (59) | Shutdown and closed. | 2015-02-13 09:37:26
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:37:26 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:37:26 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:37:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:37:26
Disconnected from IB. | 2015-02-13 09:37:26
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:37:26
Starting TWS auto-login thread. | 2015-02-13 09:40:17
TWS auto-login thread ending. | 2015-02-13 09:40:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:40:26
Socket (60) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:40:28
Socket (60) | Shutdown and closed. | 2015-02-13 09:40:28
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:40:28 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:40:28 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:40:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:40:28
Disconnected from IB. | 2015-02-13 09:40:28
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:40:28
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:43:28
Socket (61) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:43:29
Socket (61) | Shutdown and closed. | 2015-02-13 09:43:29
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:43:29 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:43:29 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:43:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:43:29
Disconnected from IB. | 2015-02-13 09:43:29
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:43:29
Starting TWS auto-login thread. | 2015-02-13 09:44:17
TWS auto-login thread ending. | 2015-02-13 09:44:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:46:29
Socket (62) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:46:30
Socket (62) | Shutdown and closed. | 2015-02-13 09:46:30
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:46:30 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:46:30 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:46:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:46:30
Disconnected from IB. | 2015-02-13 09:46:30
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:46:30
Starting TWS auto-login thread. | 2015-02-13 09:48:17
TWS auto-login thread ending. | 2015-02-13 09:48:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:49:30
Socket (63) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:49:31
Socket (63) | Shutdown and closed. | 2015-02-13 09:49:31
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:49:31 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:49:31 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:49:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:49:31
Disconnected from IB. | 2015-02-13 09:49:31
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:49:31
Starting TWS auto-login thread. | 2015-02-13 09:52:17
TWS auto-login thread ending. | 2015-02-13 09:52:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:52:31
Socket (64) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:52:32
Socket (64) | Shutdown and closed. | 2015-02-13 09:52:32
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:52:32 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:52:32 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:52:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:52:32
Disconnected from IB. | 2015-02-13 09:52:32
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:52:32
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:55:32
Socket (65) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:55:33
Socket (65) | Shutdown and closed. | 2015-02-13 09:55:33
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:55:33 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:55:33 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:55:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:55:33
Disconnected from IB. | 2015-02-13 09:55:33
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:55:33
Starting TWS auto-login thread. | 2015-02-13 09:56:17
TWS auto-login thread ending. | 2015-02-13 09:56:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 09:58:33
Socket (66) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 09:58:34
Socket (66) | Shutdown and closed. | 2015-02-13 09:58:34
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 09:58:34 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 09:58:34 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 09:58:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 09:58:34
Disconnected from IB. | 2015-02-13 09:58:34
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 09:58:34
Starting TWS auto-login thread. | 2015-02-13 10:00:17
TWS auto-login thread ending. | 2015-02-13 10:00:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:01:34
Socket (67) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:01:35
Socket (67) | Shutdown and closed. | 2015-02-13 10:01:35
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:01:35 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:01:35 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:01:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:01:35
Disconnected from IB. | 2015-02-13 10:01:35
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:01:35
Starting TWS auto-login thread. | 2015-02-13 10:04:17
TWS auto-login thread ending. | 2015-02-13 10:04:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:04:35
Socket (68) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:04:36
Socket (68) | Shutdown and closed. | 2015-02-13 10:04:36
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:04:36 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:04:36 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:04:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:04:36
Disconnected from IB. | 2015-02-13 10:04:36
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:04:36
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:07:36
Socket (69) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:07:37
Socket (69) | Shutdown and closed. | 2015-02-13 10:07:37
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:07:37 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:07:37 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:07:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:07:37
Disconnected from IB. | 2015-02-13 10:07:37
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:07:37
Starting TWS auto-login thread. | 2015-02-13 10:08:17
TWS auto-login thread ending. | 2015-02-13 10:08:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:10:37
Socket (70) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:10:38
Socket (70) | Shutdown and closed. | 2015-02-13 10:10:38
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:10:38 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:10:38 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:10:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:10:38
Disconnected from IB. | 2015-02-13 10:10:38
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:10:38
Starting TWS auto-login thread. | 2015-02-13 10:12:17
TWS auto-login thread ending. | 2015-02-13 10:12:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:13:38
Socket (71) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:13:39
Socket (71) | Shutdown and closed. | 2015-02-13 10:13:39
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:13:39 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:13:39 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:13:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:13:39
Disconnected from IB. | 2015-02-13 10:13:39
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:13:39
Starting TWS auto-login thread. | 2015-02-13 10:16:17
TWS auto-login thread ending. | 2015-02-13 10:16:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:16:39
Socket (72) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:16:40
Socket (72) | Shutdown and closed. | 2015-02-13 10:16:40
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:16:40 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:16:40 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:16:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:16:40
Disconnected from IB. | 2015-02-13 10:16:40
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:16:40
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:19:40
Socket (73) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:19:41
Socket (73) | Shutdown and closed. | 2015-02-13 10:19:41
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:19:41 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:19:41 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:19:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:19:41
Disconnected from IB. | 2015-02-13 10:19:41
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:19:41
Starting TWS auto-login thread. | 2015-02-13 10:20:17
TWS auto-login thread ending. | 2015-02-13 10:20:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:22:41
Socket (74) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:22:42
Socket (74) | Shutdown and closed. | 2015-02-13 10:22:42
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:22:42 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:22:42 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:22:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:22:42
Disconnected from IB. | 2015-02-13 10:22:42
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:22:42
Starting TWS auto-login thread. | 2015-02-13 10:24:17
TWS auto-login thread ending. | 2015-02-13 10:24:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:25:42
Socket (75) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:25:43
Socket (75) | Shutdown and closed. | 2015-02-13 10:25:43
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:25:43 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:25:43 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:25:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:25:43
Disconnected from IB. | 2015-02-13 10:25:43
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:25:43
Starting TWS auto-login thread. | 2015-02-13 10:28:17
TWS auto-login thread ending. | 2015-02-13 10:28:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:28:43
Socket (76) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:28:44
Socket (76) | Shutdown and closed. | 2015-02-13 10:28:44
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:28:44 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:28:44 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:28:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:28:44
Disconnected from IB. | 2015-02-13 10:28:44
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:28:44
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:31:44
Socket (77) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:31:45
Socket (77) | Shutdown and closed. | 2015-02-13 10:31:45
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:31:45 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:31:45 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:31:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:31:45
Disconnected from IB. | 2015-02-13 10:31:45
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:31:45
Starting TWS auto-login thread. | 2015-02-13 10:32:17
TWS auto-login thread ending. | 2015-02-13 10:32:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:34:45
Socket (78) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:34:46
Socket (78) | Shutdown and closed. | 2015-02-13 10:34:46
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:34:46 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:34:46 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:34:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:34:46
Disconnected from IB. | 2015-02-13 10:34:46
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:34:46
Starting TWS auto-login thread. | 2015-02-13 10:36:17
TWS auto-login thread ending. | 2015-02-13 10:36:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:37:46
Socket (79) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:37:47
Socket (79) | Shutdown and closed. | 2015-02-13 10:37:47
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:37:47 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:37:47 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:37:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:37:47
Disconnected from IB. | 2015-02-13 10:37:47
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:37:47
Starting TWS auto-login thread. | 2015-02-13 10:40:17
TWS auto-login thread ending. | 2015-02-13 10:40:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:40:47
Socket (80) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:40:48
Socket (80) | Shutdown and closed. | 2015-02-13 10:40:48
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:40:48 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:40:48 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:40:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:40:48
Disconnected from IB. | 2015-02-13 10:40:48
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:40:48
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:43:48
Socket (81) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:43:49
Socket (81) | Shutdown and closed. | 2015-02-13 10:43:49
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:43:49 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:43:49 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:43:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:43:49
Disconnected from IB. | 2015-02-13 10:43:49
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:43:49
Starting TWS auto-login thread. | 2015-02-13 10:44:17
TWS auto-login thread ending. | 2015-02-13 10:44:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:46:49
Socket (82) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:46:50
Socket (82) | Shutdown and closed. | 2015-02-13 10:46:50
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:46:50 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:46:50 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:46:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:46:50
Disconnected from IB. | 2015-02-13 10:46:50
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:46:50
Starting TWS auto-login thread. | 2015-02-13 10:48:17
TWS auto-login thread ending. | 2015-02-13 10:48:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:49:50
Socket (83) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:49:51
Socket (83) | Shutdown and closed. | 2015-02-13 10:49:51
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:49:51 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:49:51 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:49:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:49:51
Disconnected from IB. | 2015-02-13 10:49:51
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:49:51
Starting TWS auto-login thread. | 2015-02-13 10:52:17
TWS auto-login thread ending. | 2015-02-13 10:52:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:52:51
Socket (84) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:52:52
Socket (84) | Shutdown and closed. | 2015-02-13 10:52:52
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:52:52 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:52:52 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:52:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:52:52
Disconnected from IB. | 2015-02-13 10:52:52
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:52:52
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:55:52
Socket (85) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:55:53
Socket (85) | Shutdown and closed. | 2015-02-13 10:55:53
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:55:53 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:55:53 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:55:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:55:53
Disconnected from IB. | 2015-02-13 10:55:53
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:55:53
Starting TWS auto-login thread. | 2015-02-13 10:56:17
TWS auto-login thread ending. | 2015-02-13 10:56:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 10:58:54
Socket (86) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 10:58:55
Socket (86) | Shutdown and closed. | 2015-02-13 10:58:55
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 10:58:55 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 10:58:55 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 10:58:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 10:58:55
Disconnected from IB. | 2015-02-13 10:58:55
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 10:58:55
Starting TWS auto-login thread. | 2015-02-13 11:00:17
TWS auto-login thread ending. | 2015-02-13 11:00:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:01:55
Socket (87) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:01:56
Socket (87) | Shutdown and closed. | 2015-02-13 11:01:56
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:01:56 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:01:56 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:01:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:01:56
Disconnected from IB. | 2015-02-13 11:01:56
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:01:56
Starting TWS auto-login thread. | 2015-02-13 11:04:17
TWS auto-login thread ending. | 2015-02-13 11:04:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:04:56
Socket (88) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:04:57
Socket (88) | Shutdown and closed. | 2015-02-13 11:04:57
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:04:57 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:04:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:04:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:04:57
Disconnected from IB. | 2015-02-13 11:04:57
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:04:57
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:07:57
Socket (89) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:07:58
Socket (89) | Shutdown and closed. | 2015-02-13 11:07:58
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:07:58 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:07:58 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:07:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:07:58
Disconnected from IB. | 2015-02-13 11:07:58
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:07:58
Starting TWS auto-login thread. | 2015-02-13 11:08:17
TWS auto-login thread ending. | 2015-02-13 11:08:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:10:58
Socket (90) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:10:59
Socket (90) | Shutdown and closed. | 2015-02-13 11:10:59
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:10:59 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:10:59 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:10:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:10:59
Disconnected from IB. | 2015-02-13 11:10:59
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:10:59
Starting TWS auto-login thread. | 2015-02-13 11:12:17
TWS auto-login thread ending. | 2015-02-13 11:12:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:13:59
Socket (91) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:14:00
Socket (91) | Shutdown and closed. | 2015-02-13 11:14:00
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:14:00 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:14:00 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:14:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:14:00
Disconnected from IB. | 2015-02-13 11:14:00
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:14:00
Starting TWS auto-login thread. | 2015-02-13 11:16:17
TWS auto-login thread ending. | 2015-02-13 11:16:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:17:00
Socket (92) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:17:01
Socket (92) | Shutdown and closed. | 2015-02-13 11:17:01
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:17:01 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:17:01 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:17:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:17:01
Disconnected from IB. | 2015-02-13 11:17:01
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:17:01
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:20:01
Socket (93) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:20:02
Socket (93) | Shutdown and closed. | 2015-02-13 11:20:02
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:20:02 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:20:02 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:20:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:20:02
Disconnected from IB. | 2015-02-13 11:20:02
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:20:02
Starting TWS auto-login thread. | 2015-02-13 11:20:17
TWS auto-login thread ending. | 2015-02-13 11:20:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:23:02
Socket (94) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:23:03
Socket (94) | Shutdown and closed. | 2015-02-13 11:23:03
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:23:03 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:23:03 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:23:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:23:03
Disconnected from IB. | 2015-02-13 11:23:03
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:23:03
Uploaded an image to the server. Request ID: 2 | 2015-02-13 11:23:18
Starting TWS auto-login thread. | 2015-02-13 11:24:17
TWS auto-login thread ending. | 2015-02-13 11:24:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:26:03
Socket (95) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:26:04
Socket (95) | Shutdown and closed. | 2015-02-13 11:26:04
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:26:04 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:26:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:26:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:26:04
Disconnected from IB. | 2015-02-13 11:26:04
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:26:04
Starting TWS auto-login thread. | 2015-02-13 11:28:17
TWS auto-login thread ending. | 2015-02-13 11:28:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:29:04
Socket (96) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:29:05
Socket (96) | Shutdown and closed. | 2015-02-13 11:29:05
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:29:05 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:29:05 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:29:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:29:05
Disconnected from IB. | 2015-02-13 11:29:05
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:29:05
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:32:05
Socket (97) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:32:06
Socket (97) | Shutdown and closed. | 2015-02-13 11:32:06
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:32:06 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:32:06 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:32:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:32:06
Disconnected from IB. | 2015-02-13 11:32:06
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:32:06
Starting TWS auto-login thread. | 2015-02-13 11:32:17
TWS auto-login thread ending. | 2015-02-13 11:32:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:35:06
Socket (98) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:35:07
Socket (98) | Shutdown and closed. | 2015-02-13 11:35:07
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:35:07 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:35:07 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:35:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:35:07
Disconnected from IB. | 2015-02-13 11:35:07
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:35:07
Starting TWS auto-login thread. | 2015-02-13 11:36:17
TWS auto-login thread ending. | 2015-02-13 11:36:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:38:07
Socket (99) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:38:08
Socket (99) | Shutdown and closed. | 2015-02-13 11:38:08
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:38:08 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:38:08 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:38:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:38:08
Disconnected from IB. | 2015-02-13 11:38:08
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:38:08
Starting TWS auto-login thread. | 2015-02-13 11:40:17
TWS auto-login thread ending. | 2015-02-13 11:40:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:41:08
Socket (100) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:41:09
Socket (100) | Shutdown and closed. | 2015-02-13 11:41:09
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:41:09 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:41:09 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:41:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:41:09
Disconnected from IB. | 2015-02-13 11:41:09
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:41:09
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-02-13 11:44:09
Socket (101) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-02-13 11:44:10
Socket (101) | Shutdown and closed. | 2015-02-13 11:44:10
Interactive Brokers | Failed to connect to the data and trade server. | 2015-02-13 11:44:10 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-02-13 11:44:10 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-13 11:44:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-13 11:44:10
Disconnected from IB. | 2015-02-13 11:44:10
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-13 11:44:10
Starting TWS auto-login thread. | 2015-02-13 11:44:17
TWS auto-login thread ending. | 2015-02-13 11:44:17
Do I need for IB Live acc't or Sim. Acc't user&pass <> That I use for IB.
>>>> Live I need a 2nd password only i have. See no place on Sierra for it........
Assuming I need the one I use to get into IB.
Do I need to change or do with IB acc't. you should know ?~~
[2015-02-13 19:09:31]
Refer to step 22 in the set up instructions here for help with connection problems:
https://www.sierrachart.com/index.php?page=doc/IB.php#SetupInstructions
[2015-02-14 01:29:17]
User72965 - Posts: 115
We finally got live Data :)
Had to go into IB And Activate API ..
I called IB as had no API
Had to download the Latest TWS app.
Then after 2-3 tries got it working !!
Finally got Charts going . need IB platform open
to get started.
Do I need CBOE & SP Indices ??? Follow Mini ES
Oil Euro SPY And TF I see need to Activate TF 2-3.00~~~
Thx Gene Sheldon ~~ Man what A Battle !!!! :)
[2015-02-14 01:57:02]
Yes, we agree that it is a difficult process. Contending with Interactive Brokers all of the exchange regulations to get this working is a hassle.
Based on your requirements you would need to activate US Equities and ICE US.
[2015-02-14 13:30:07]
Yes > When I went into Sierra support > Saw IB had moer than most of the others ~~
Figured be a job. Luckily had a couple of other IB users , to help figure it all out :)
Thx for the ref. US Equities&ICE US .. I'll ck. them out .
Guess still need CBOE&ES Indices <> think they are EX. Fees. Pd them over at DTN also.
We gave Sierra feed test run,Fri. at and into early after hours <. Seemed to be right on~~~
Thx Gene ~~
