Date/Time: Sun, 22 Dec 2024 11:42:35 +0000
Bug in the displaying of the Triangle
View Count: 1161
[2015-02-11 20:22:41]
Marek F - Posts: 244
The Triangle Up is displaying with a smaller size than a size of other kind of Triangles (Down, Left, Right).
Every they have set the same Size in the Marker Properties.
The same problem is if i use the Triangle Marker by UseTool.
Best Regards
Marek
