Date/Time: Thu, 25 Jun 2026 00:34:15 +0000
New replay feature getting stuck.
View Count: 2039
| [2013-05-25 11:39:24] |
| User87197 - Posts: 65 |
Hiya. After a little testing with the awesome new multiple replay-speeds feature that you very kindly added to the replay box (currently in the pre-release) - it would appear that when I'm mid-replay and i'm pressing cursor 'down' to slow the replay speed it seems to stop playback unless I increase the speed again. There seems to be a couple of anomalies while trying to cycle up and down through different speeds mid-playback and I've tried it on multiple instruments and chart setups. If you could take a look at this I'd really appreciate it. Thanks! :)
| [2013-05-25 20:45:01] |
This could be. This is probably just to to the significant changes in timing. It's not something we can spend any time on right now.
| [2013-07-22 02:38:34] |
We apologize for the delay with this. We now understand why this is happening and it will be resolved in the next release.
| [2013-07-22 13:51:23] |
That's because you're the best, thanks SC! :)
