Date/Time: Sun, 22 Dec 2024 11:22:28 +0000
[User Discussion] - spreadsheet formula ?
View Count: 963
[2015-02-11 16:00:01]
User52239 - Posts: 13
When trying to get a crossover signal with the swing high-low indicator, I cannot seem to get it to work.
Is it because many of the cells get filled with zeros when a swing high-low does not form?
I try the last price =crossfrombelow(E3,AB3:AB4) where ab3 is the swing high cell.
If it is an issue with the zeros in the cells, how do you overcome this ?
I cant get it to work with ASCIL crossover either.
thanks
Shane
Date Time Of Last Edit: 2015-02-11 16:38:26
[2015-02-11 21:17:43]
Sawtooth - Posts: 4141
As you suspected, it is because of the zeros.
Attached is an example of how to overcome it with a spreadsheet study.
attachmentSwing HL extended.cht - Attached On 2015-02-11 21:16:52 UTC - Size: 38.33 KB - 453 views
attachmentSwing HL extended.scwbf - Attached On 2015-02-11 21:17:15 UTC - Size: 36.82 KB - 428 views
[2015-02-11 22:34:31]
thanks so much Tom !
Although I cannot figure out how you changed the zero settings. Or which setting you used.
shane
Date Time Of Last Edit: 2015-02-11 22:42:30
[2015-02-11 22:52:59]
The Swing HL study is Hidden. What you see displayed is from the spreadsheet study. Look at the Draw Styles of the spreadsheet columns M (SG3) and P (SG6). These are the only ones displayed.
[2015-02-11 23:51:58]
Hi
I see now.
How can I add a formula with a trading spreadsheet to get a buy signal when price breaks a previous swing high or low ?
thanks Tom
shane
[2015-02-12 00:43:34]
My example chartbook gives you more than you need. Just use the formulas in K3 and N3, with these for entries:
=CROSSFROMBELOW(E3:E4,K3:K4)
=CROSSFROMABOVE(E3:E4,N3:N4)
