Date/Time: Thu, 17 Sep 2026 00:45:41 +0000
Is there a way to measure a candle to show it's number of ticks/size
View Count: 2157
| [2015-02-11 15:45:02] |
| User428971 - Posts: 26 |
Is there a tool that if you click on the top and bottom of a candle it quickly shows the size in ticks. Thank you.
| [2015-02-11 16:16:38] |
No, but there is the "Bar Difference" study which will display a graph of this.
| [2015-02-11 20:29:08] |
ok, can you point me in the direction to find this... I looked all over. Thank you.
| [2015-02-11 22:27:55] |
Never mind, I found it. However it doesn't really do what I would like. It would be great to have a tool that could be right click at one place then let go in another place and have it tell me how many ticks that is, which is what I would use it for in scalping. Something fast. I do like everything else with Sierra Charts. Thank you.
| [2015-02-11 22:46:42] |
| Sawtooth - Posts: 4354 |
Go to Tools >> Chart Calculator. To configure that tool, go to Tools >> Tool Configs >> Chart Calculator Config |
| [2015-02-12 02:23:22] |
Here is the documentation for this study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s56 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-02-12 02:35:37] |
A huge THANK YOU, tomgilb, you saved the day! Best of trades to you!!!
