Date/Time: Sun, 22 Dec 2024 11:17:56 +0000
Real time data issue
View Count: 946
[2015-02-11 11:43:22] |
User19390 - Posts: 2 |
Dir Sir/Madame, I am using sierra chart as Trial. I paid for real time data ( Sierra Chart Real-Time and Historical Exchange Data Feed). And also paid for fee for CME group. I would like to have real time tick data for "NQ" but I do not have it. I have live account in Interactive Brokers. I would like to use Number bars. What am I doing wrong? Can you pl. hepl? Thank you, Erik |
[2015-02-11 16:55:59] |
In the case of CME data, you must set Sierra Chart to use your Interactive Brokers account to access that data. This is explained here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration Here are the Interactive Brokers set up instructions: https://www.sierrachart.com/index.php?page=doc/IB.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-12 13:47:00] |
The problem was, I was connecting to SC exange data instead to Interactive broker data. All I need to do is connect to IB and mark (allow support for SC data feeds) under data trade service settings. Tx, Erik |
