Date/Time: Sun, 22 Dec 2024 11:12:54 +0000
Volume Profile Outline
View Count: 1258
[2015-02-11 06:11:21] |
User93757 - Posts: 61 |
Hi, Been having an issue with Volume Profile Settings -> Draw Volume Profile Outline Only -> Value Area And Outline -> Width/Size. The Width/Size of the outline does not change when you change the size of the line. It works fine on the Volume Bars Outline and Fill Color. Please see sample attached. Thx |
Sierra_VP_Outline.png / V - Attached On 2015-02-11 06:10:18 UTC - Size: 40.31 KB - 493 views |
[2015-02-12 03:15:16] |
This will be solved in the next release.
[2015-02-12 05:28:45] |
Thx!
