Date/Time: Thu, 16 Jan 2025 08:58:18 +0000
VbP bug when switching to daily
View Count: 1076
[2015-02-10 23:43:29] |
joshtrader - Posts: 496 |
When switching from an intraday to a daily chart and back to intraday, the "ticks per bar" setting in VbP will now be 5, even if it was 1 before. I understand that it changes to match the volume multiplier that sometimes happens when switching to daily, but it is not getting switched back.
[2015-02-13 04:24:15] |
We will solve this.
[2017-10-26 00:18:31] |
samual sprat - Posts: 343 |
Hi. I'm having this exact problem atm. Did it get fixed?
[2017-10-26 01:38:05] |
No, but we did implement a solution now for this. This will be out in the next release.
