Date/Time: Sun, 22 Dec 2024 10:30:21 +0000
Chart
View Count: 839
[2015-02-10 20:42:55]
User905901 - Posts: 18
Hi SC Support Board,
I have a problem with applying arrows as a result of formulas from Spreadsheet into a chart.
I can see them only at the bottom of the chart. I need to see the arrows right above or under the bars.
Recently it worked properly.
I have also attached my settings and chart.
Thanks for your advice.
attachmentSC_1.pdf - Attached On 2015-02-10 20:41:14 UTC - Size: 110.67 KB - 479 views
[2015-02-11 09:38:17]
I would appreciate some advice.
Thanks.
[2015-02-11 13:09:44]
Sawtooth - Posts: 4141
Change your formulas to these:
Up arrow:
=IF(YourOrigFormula,D3,0)
Down Arrow:
=IF(YourOrigFormula,C3,0)
[2015-02-11 13:54:08]
Hi Tom,
it works now.
Thanks a lot.
