Date/Time: Sun, 22 Dec 2024 10:39:29 +0000
help with connection
View Count: 811
[2015-02-10 15:13:52] |
User61042 - Posts: 5 |
the platform does not connect. always show yellow advice
[2015-02-10 16:45:11] |
We see you are using Open E Cry. The connection should be working now.
