Date/Time: Sun, 22 Dec 2024 10:01:53 +0000
Delete copied chart drawing
View Count: 1323
[2015-02-10 14:30:08] |
Halir - Posts: 2 |
Could you implement optional functionality to delete chart drawing such as lines, rays, rectangles from other charts then where the drawing was originally created? After deletion the drawing would certainly disappear from all charts where the drawing was shown. This is because I am working and creating drawings in multiple charts. When I need to delete the drawing it is often difficult and slow to find on which chart the drawing was created. The drawings are copied between charts with the "Copy Chart Drawing From Chart #'s:" option in Chart settings. e.g. You could add an option into Chart Settings -> Advanced Settings 2 -> "Allow copied chart drawing deletion" or more granual "Allow copied chart drawing deletion from Chart #'s:"
