Date/Time: Sun, 22 Dec 2024 09:57:27 +0000
Connection Not Working
View Count: 831
[2015-02-10 13:49:30] |
User88640 - Posts: 4 |
For Open Ecry - Demo060024 is my account thats not connecting to the datafeed. Please fix, thanks.
[2015-02-10 16:50:14] |
Open E Cry had a problem earlier with their server. You should be able to connect now. If not, refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/openecry.php#OECConnectionProblem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
