Date/Time: Mon, 21 Sep 2026 09:42:30 +0000
OEC Connection Issues here too
View Count: 1557
| [2015-02-10 13:16:09] |
| User74987 - Posts: 16 |
trying to connect to OEC for more than 30 minutes also. have logged off and rebooted a couple of times. no help. same message comes up each time. Open E Cry FIX | Connecting to trading server prod.openecry.com:9400. | 2015-02-10 07:11:33 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 208.91.197.132 | 2015-02-10 07:11:33 OEC FIX Trading socket (6) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-02-10 07:11:54 OEC FIX Trading socket (6) | Shutdown and closed. | 2015-02-10 07:11:54 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2015-02-10 07:11:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-02-10 07:11:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-02-10 07:11:54 OEC FIX Trading: DisconnectFIX called. | 2015-02-10 07:11:54 Disconnected from Open E Cry. | 2015-02-10 07:11:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-10 07:11:54 |
| [2015-02-10 15:17:40] |
| NRGTrader - Posts: 351 |
I'm thinking it's a DNS issue. I had this problem once about 5 years ago. The solution was adding a IP address line in the hosts file.
| [2015-02-10 16:20:20] |
In response to the first post, are you still having a problem connecting to OEC?
