Date/Time: Sun, 22 Dec 2024 10:04:11 +0000
SC 1229 : Problems Alert
View Count: 899
[2015-02-09 10:32:38] |
salsem - Posts: 43 |
Hello SC Support, SC Version 1229 I have problems with alert Keltner channel = OR (C> SG2, C <SG3) with previous versions SC I never had problems Thanks in advance |
[2015-02-09 18:10:11] |
We are looking into this now.
[2015-02-09 22:38:26] |
This has been solved. Refer to these instructions to update Sierra Chart: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
