Date/Time: Sun, 22 Dec 2024 11:50:09 +0000
Volume Distribution Paint Bar Study
View Count: 1733
[2015-02-09 06:04:14] |
User77091 - Posts: 7 |
Can you make an option to enter the percentage for the top high/low instead of using the fixed 15%. Can you make this study work with a price volume bar chart? |
[2015-02-09 08:03:11] |
An adjustable percentage will be supported in the next release. We will see about the other request. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-09 08:03:24
