Date/Time: Sun, 22 Dec 2024 11:54:31 +0000
[User Discussion] - Black icons in the top toolbar issue.
View Count: 950
[2015-02-08 21:05:16] |
V.B - Posts: 2 |
Hello, I have a black buttons in the top toolbar issue. Here is a screenshot: http://www.sierrachart.com/image.php?l=1423429086181.png I run the latest version 1224 thru wine ver. 1.4.1-4 on debian 7 (wheezy). Global Settings > General 2 > "use icons for toolbar button" is unchecked. Is there a way to fix this? Thank you, Valentine. |
[2015-02-08 23:10:40] |
Not sure what the exact solution would be, but we believe it is something related to the available fonts within Wine.
[2015-02-09 03:48:38] |
ganz - Posts: 1048 |
V.B FYI: Non NET version toolbar buttons Graphics performance issue on Linux/Wine |
[2015-02-09 04:17:59] |
V.B - Posts: 2 |
thanks a lot ganz. I fixed the issue with your info in the fist thread. :-) |
