Date/Time: Sun, 22 Dec 2024 11:40:00 +0000
Stock Index Future to Cash Index Premiums
View Count: 1749
[2015-02-08 09:29:47] |
For the four major stock indices in the US, the premium the futures market has to the cash index is now available with the Sierra Chart Exchange Data Feed. Refer to the attachment for the symbols. There are two exchanges which need to be subscribed to in order to get data for the premiums. The one for the futures and the one for the cash index, in order to get this data. You can see both exchanges on the description line at the end. Each of these premiums though requires a different cash indices exchange fee. We will be adding these symbols to all of the supported Trading services. However, to be clear, what this means is you will be able to get this data if you are paying for the Sierra Chart Exchange Data Feed and the symbols will be integrated with the Trading service you are using. Once again there are two exchange fees that have to be paid. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-08 23:07:28
Stock Index Future Premiums.png / V - Attached On 2015-02-08 09:28:45 UTC - Size: 25.46 KB - 478 views |
[2015-02-13 03:20:44] |
The stock index premiums are now functional. Sierra Chart version 1231 or higher is required to use them. Here is an example: http://www.sierrachart.com/image.php?l=1423797633653.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
