Date/Time: Sun, 22 Dec 2024 11:03:57 +0000
Intraday File Update List
View Count: 970
[2015-02-08 06:36:01] |
User22085 - Posts: 11 |
Hi, I see that in the newer versions of SC there is not Intraday File Update List (Edit -> Intraday File Update Lits). Could anybody say how to get access to Symbol List or any other way to manage symbols that get updated intraday? Regards, kras |
[2015-02-09 04:24:53] |
It is there but it is under the Global Settings menu. It has always been listed under Global Settings as well but removed from the Edit menu.
[2015-02-09 08:43:40] |
Thank you!
