Date/Time: Tue, 29 Sep 2026 08:03:26 +0000
IsCustomChart = 1
View Count: 3033
| [2015-02-07 20:25:34] |
| QnReally - Posts: 188 |
I was testing the example shown below to learn how it works. http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scIsCustomChart I started with the scsf_CopyOfBaseGraph(). One modification I did is, I subtracted 10.00 from each of the OHLC values. The new custom bars shifted down by 10.00 correctly. I then added a Volume By Price study to this. The profile is displaying at the original values rather than at 10.00 points below. Here is the visual: http://www.sierrachart.com/image.php?l=1423340808828.png Can you please confirm or look into this? Thanks. Date Time Of Last Edit: 2015-02-07 20:27:33
| [2015-02-08 00:56:36] |
| Kiwi - Posts: 375 |
I tend to carefully make sure that my studies are based on the function they're using. What happens if you change VbP to be based on your new function. Any change? http://i.imgur.com/MzjXKIv.png |
| [2015-02-08 01:14:27] |
No change Kiwi. The Profile remains 10 points higher. I have also tried the following: 1) Set Display As Main Price Graph on a custom study that has OHLC, Volume, Number of Trades, Bid Volume, Ask Volume subgraphs all set. The VBP still picks up the base graph data which is now been overridden. 2) I used the Study/Price Overlay study and tried the Display As Main Price Graph option to overlay ES main graph over the NQ chart. The VBP draws the profile at NQ prices. Thanks for looking into this and I welcome any other pointers. Date Time Of Last Edit: 2015-02-08 01:22:09
| [2015-02-08 01:23:52] |
SCSFExport scsf_BaseGraphDisplacement(SCStudyInterfaceRef sc)
{ SCSubgraphRef Open = sc.Subgraph[0]; SCSubgraphRef High = sc.Subgraph[1]; SCSubgraphRef Low = sc.Subgraph[2]; SCSubgraphRef Last = sc.Subgraph[3]; SCSubgraphRef Volume = sc.Subgraph[4]; SCSubgraphRef OpenInterest = sc.Subgraph[5]; SCSubgraphRef OHLCAvg = sc.Subgraph[6]; SCSubgraphRef HLCAvg = sc.Subgraph[7]; SCSubgraphRef HLAvg = sc.Subgraph[8]; //SCSubgraphRef BidVol = sc.Subgraph[9]; // SCSubgraphRef AskVol = sc.Subgraph[10]; SCInputRef GraphDisplacement = sc.Input[0]; // Set configuration variables if (sc.SetDefaults) { // Set the defaults sc.GraphName = "BaseGraph Displacement Example"; sc.StudyDescription = "This is an example of how to create a custom chart. This one is a copy of the BaseGraph."; // This member indicates that this is a custom chart study. // This can only be set when SetDefaults is true. sc.IsCustomChart = 1; // true sc.GraphRegion = 0; // First region sc.DrawZeros = 0; // false sc.GraphDrawType = GDT_OHLCBAR; sc.StandardChartHeader = 1; // true // Subgraphs Open.Name = "Open"; Open.DrawStyle = DRAWSTYLE_LINE; High.Name = "High"; High.DrawStyle = DRAWSTYLE_LINE; Low.Name = "Low"; Low.DrawStyle = DRAWSTYLE_LINE; Last.Name = "Last"; Last.DrawStyle = DRAWSTYLE_LINE; Volume.Name = "Volume"; Volume.DrawStyle = DRAWSTYLE_IGNORE; OpenInterest.Name = "# of Trades / OI"; OpenInterest.DrawStyle = DRAWSTYLE_IGNORE; OHLCAvg.Name = "OHLC Avg"; OHLCAvg.DrawStyle = DRAWSTYLE_IGNORE; HLCAvg.Name = "HLC Avg"; HLCAvg.DrawStyle = DRAWSTYLE_IGNORE; HLAvg.Name = "HL Avg"; HLAvg.DrawStyle = DRAWSTYLE_IGNORE; /* BidVol.Name = "Bid Vol"; BidVol.DrawStyle = DRAWSTYLE_IGNORE; AskVol.Name = "Ask Vol"; AskVol.DrawStyle = DRAWSTYLE_IGNORE;*/ GraphDisplacement.Name = "Diplacement Amount"; GraphDisplacement.SetDescription("The amount to add to the base graph values. This can be positive or negative."); GraphDisplacement.SetFloat(0.0f); GraphDisplacement.SetFloatLimits(-10000.0f, 10000.0f); return; } // If our start index is zero, then we want to clear our existing chart // data, if any, so we start clean to avoid any possible problems. This // is accomplished by using sc.ResizeArrays. if (sc.UpdateStartIndex == 0) { sc.ResizeArrays(0); } // Do data processing for (int i = sc.UpdateStartIndex; i < sc.ArraySize; i++) { if (sc.OutArraySize - 1 < i) sc.AddElements(1); sc.DateTimeOut[i] = sc.BaseDateTimeIn[i]; for (int SubGraph = 0; SubGraph <= 8; SubGraph++) { if (SubGraph >= 0 && SubGraph <= 3) sc.Subgraph[SubGraph][i] = sc.BaseDataIn[SubGraph][i] + GraphDisplacement.GetFloat(); else sc.Subgraph[SubGraph][i] = sc.BaseDataIn[SubGraph][i]; //For testing coloring bars //sc.Subgraph[SubGraph].DataColor[i] = RGB(255,255,255); } } } |
| [2015-02-08 09:26:24] |
Volume at Price data will not be affected by custom charts.
