Date/Time: Fri, 22 Nov 2024 18:40:01 +0000
CL 2:30 bid ask problems
View Count: 1619
[2013-05-24 18:42:05] |
pismo10 - Posts: 159 |
Everyday at precisely 2:30pm ET my bid ask size data on CL goes haywire. Bid and ask sizes all over the place, crossed, etc. If I exit and re-enter the program it is corrected. Using IB data Any idea? Thanks |
[2013-05-24 18:52:37] |
Yes. Use another service other than Interactive Brokers. For the time being when you notice this, reconnect to the data feed using the commands in the File menu.
