Date/Time: Sun, 22 Dec 2024 11:38:42 +0000
Use Fill Calculated Position
View Count: 1229
[2015-02-06 21:16:13] |
katek - Posts: 28 |
Hello I am using the "Trade>Use Fill Calculated Position" functionality. However even though I am flat, the chart is showing a short position. I've tried to correct the issue by clearing the Trade Activity Log. I've also tried the "Refresh Trade Data From Service" But still the chart is wrongly showing the short position. How can I reset it or clear the chart from the erroneous position? |
[2015-02-09 16:53:33] |
Do these two things: 1.Uncheck Global Settings >> Data/Trade Service Settings >> Trade Settings >>Download Historical Order Fills on Connect. 2. Carefully follow through the instructions to clear the Trade Activity data: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ClearingtheLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
