Date/Time: Thu, 17 Sep 2026 04:43:37 +0000
Volume > Prior Candle Volume
View Count: 1336
| [2015-02-06 15:49:10] |
| infpz - Posts: 826 |
Volume is ID1.SG1. I just want an alert if the volume of the current bar exceeds the volume of the prior bar. Should this code work? =ID1.SG1>ID1.SG1[-1] Here is the error: Alert Formula Error - Chart: ESH5 1 Min #4 | Study: Color Background Based On Alert Condition | Error: #NAME? | Formula: =AND(ID1.SG1>ID2.SG1*2,ID1.SG1>ID1.SG1[-1]) | No alert sound/email There is another study that is part of the alert - that is not the problem as it works on its own. Thanks for any input, PZ |
| [2015-02-06 17:43:44] |
It could be the ID numbers are wrong. Check them to make sure those are the actual correct study ID numbers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-02-06 18:07:32] |
It is definitely ID1.SG1 - could it be anything else?
| [2015-02-06 18:08:54] |
Strangely, when I put this condition onto a fresh chart with no other studies, it works fine.
| [2015-02-07 22:36:06] |
| FFTrader - Posts: 180 |
I have the same problem. What is really strange is that the studies had no issues whatsoever prior to. Today, when I try to edit and then save a set of Study Collection, this same error came up - on one of the study that I did NOT change in the editing. What is going on?? Date Time Of Last Edit: 2015-02-07 22:36:25
| [2015-02-08 03:51:49] |
The problem went away!?!?
