Date/Time: Sun, 27 Sep 2026 23:03:05 +0000
ACSIL - Syntax of persistent pointers
View Count: 2978
| [2015-02-06 01:17:44] |
| ejtrader - Posts: 689 |
SC Team, Would you please provide the syntax for the following functions? Documentation is not available for this. Thanks sc.SetPersistentPointer() sc.GetPersistentPointer() |
| [2015-02-06 17:58:32] |
Refer to the code in this file: \ACS_Source\RequestValuesFromServerAndDraw.cpp
