Date/Time: Sun, 22 Dec 2024 11:14:20 +0000
Mr Gene Sheldon
View Count: 1364
[2015-02-05 23:41:41]
User72965 - Posts: 115
Can't download 2024 version .
My Micro Trend Anti Virus rejects it ~~
Tried disabling it. When disabled still
Blocked it. Says malicious . Won't go ?
i've done this many times before no problem.
I have to get Sierra data feed by 2-14 also.
Need to resolve this soon .!!
Thx Gene Sheldon
[2015-02-06 17:50:18]
Try downloading the non-CLR version of Sierra Chart:
https://www.sierrachart.com/downloads/SierraChartSetupNoCLR.exe
If you still have difficulty, then we recommend removing the antivirus software because if you are disabling it and is still blocking Sierra Chart , then it is still working.
Here are the instructions to use the Sierra Chart Exchange Data Feed:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
Date Time Of Last Edit: 2015-02-06 17:50:41
[2015-02-12 01:34:28]
Have all in order I think ??
No feed ??? Am I to use Barchart
On Data Trade Service Settings ?
Need user & pass From Barchart data ??
Read about need to contact you to set something ??
Not sure pertains here ???
Gene No data yet ??? I have IQFeed data
[2015-02-12 02:22:42]
What futures trading/broker service do you use? For the reason why we ask this question, refer to:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME
The Sierra Chart Exchange Data Feed is properly set up on your account. We see you have activated the CME Group Exchange. So the next step is just configuration in Sierra Chart to work with the trading service you trade through. You do not have to use Sierra Chart for trading, you just need to be able to connect to your trading service.
Date Time Of Last Edit: 2015-02-12 08:11:45
