Date/Time: Sat, 23 Nov 2024 00:03:30 +0000
Maintaining chart timeframe when changing symbol
View Count: 1655
[2013-05-24 16:08:46] |
trader1 - Posts: 128 |
Hi, I notice that every time I change the symbol in chart settings, the time frame goes from whatever time frame was set to 00:00:00 and 23:59:59. Would it be possible for you to maintain the time frame? The majority of times when someone changes the symbol they are going to desire the same or a substantially similar time frame. Thanks. |
[2013-05-24 18:47:48] |
You are referring to the Session Times. For help with this, please refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#SettingIntradaySessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-07 02:28:08] |
Hi, What symbol corresponds to any stock on the NASDAQ, NYSE, or AMEX? Thanks. |
[2013-06-07 02:31:31] |
It would be the following: * ** *** **** ***** Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
