Date/Time: Sun, 22 Dec 2024 10:00:30 +0000
String sc.PersistVar
View Count: 819
[2015-02-05 16:44:15] |
Trade Nice - Posts: 75 |
Is there a way (workaround) to program a static string variable (string sc.PersistVar)? |
[2015-02-05 16:55:17] |
You could do something as simple as: static SCString StringName; Make sure to set sc.FreeDLL = 0. And be aware that this static string is common to all instances of the study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
