Date/Time: Wed, 23 Sep 2026 21:07:41 +0000
No Reset of Replay Data when using Auto Trade System Replay Backtest
View Count: 1429
[2015-02-05 06:17:42]
sbsierra - Posts: 71
when using the ATRB I always push the "yes"-button to reset the replay backtest data.
but since version above 1220 it does not reset anymore.
is there anything changed?
best regards,
bs.trader
[2015-02-05 06:48:54]
Nothing has changed and we tested this and do not see a problem with this.
There are multiple Trade Simulation accounts, so could be that you are looking a Trade Activity data for a different account.
[2015-02-05 08:09:06]
No, I have only 1 Demoaccount activated. Do you need any logfiles?
[2015-02-05 16:58:28]
Log files are not helpful. What is the symbol of the chart and what is the simulation account the Trade Window for the chart is set to?
And how do you know the replay back test data is not being cleared? What exactly are you seeing?
