Date/Time: Mon, 13 Jul 2026 08:13:20 +0000
[User Discussion] - Spreadsheet DOM (LVL 2)
View Count: 1270
| [2015-02-05 06:07:51] |
| dem_z - Posts: 14 |
Hi - 1 - How do I display the full DOM / lvl 2 in a spreadsheet? 2 - When does the DOM update? Can it be whenever there's any change in the ladder? 3 - Can you double check if the "Depth of Market Data" study has the desired output? (second screenshot) 4 - Through ACSIL, there's not much documentation around this. The example isn't found here: https://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scSymbolData (first screenshot attached). Do you have any other examples that you could recommend that would help me learn this? Thanks! Date Time Of Last Edit: 2015-02-05 06:16:28
